| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hi all,
I wanted to mod my players with a coaxial digital output so as to connect it to my DAC. I got this circuit from the web. I tried it on my old Sony CD (model CDP 590) player which uses a CXD2500Q chip, on pin 60 (digital out) but there is no sound output from the DAC. I tried it on my old Pioneer LD (model CLD-D580) player which uses a Sanyo LC7868 1K chip, on pin 43 (digital out), again there’s no sound. I don’t think is the thin copper wire that I used between the output resistor & the RCA connector. Anyway if anyone have done this mod (that is moding your player with a digital output so as to connect it to an external DAC), if u don’t mind do share with me your knowledge & experience. Thanks!
#2 |
Yes, I've done that with a Hitachi VIP-RX8 (guts built by Pioneer) laserdisc player. It used the CXD2500AQ chip, and had traces and locations on the board for a Toslink output. Since at the time it was hard to get Toslink devices, I put in a little buffer board and an RCA jack output. I think the circuit I used was a lot like yours.
Maybe the output has to be enabled? Pin 59 is the "Digital Out On/Off Control"; High for On, Low for Off. CXD2500AQ at Alldatasheet.net |
#3 |
Hi Dangus,
Thanks for the reply. I'm not good in electronics, may i know how to enable pin 59? Is it possible that i can copy your circuit & try it out? Thanks! |
#4 | |
Stupid question I know, but did you remember to connect the power and ground pins on your 74HC04??
www.kta-hifi.net |
#5 |
Pin 59 could be connected directly, or through a resistor (10k or so) to the same supply voltage the chip uses, probably 5V. The datasheet should explain what is OK to do.
If I remember, maybe I will open up the player and take some pictures (I didn't have a camera with macro at the time I did the mod.). I've got a sketch someplace of the board layout, or maybe I can get a shot of the backside of the board if I didn't mount it too permanently. |
#6 |
Hi Kevinkr,
Yes, i did. 5V to pin 14 & gnd to pin 7 of 74HC04. Hi Dangus, I'll be happy if u can provide more info with pictures. I read a number of articles but none mentioned about enabling pin 59 of the CXD2500Q. Thanks! |
#7 |
Here's a scan of a portion of my notes that shows the schematic and board layout. I think I used the HC14 just because it was handy.
#8 |
#9 |
The 14 is a Schmitt trigger type, probably the best choice but the 04 should work fine. I have seen it mentioned somewhere that some DAC inputs use a 0 - 5 volt logic level. I can't see anything wrong, and when I last experimented with something similar ( adding an optical output ) I found it not critical at all. Whether the circuit inverts or not didn't matter. |
#10 | |
Probably doesn't make much difference in this application since the inverter is driven by a good square wave, but hysteresis is implicated as a major contributor to jitter in spdif applications. Spdif has a specific range of amplitude levels that work (well) above that range things can get very funky with receiver chips latching, etc. Below a certain level most receiver front ends won't lock properly. 400 - 500mVpp with everything properly terminated is a good number to aim for. (See my posts in the shigaclone thread for much more detail on this issue.)
www.kta-hifi.net |
| Add coaxial digital output - help | Assyst1606 | Digital Source | 2 | 3rd August 2008 08:01 AM |
| DVD963SA Digital Coaxial Out | ivor.bigun | Digital Source | 6 | 7th February 2007 12:04 AM |
| Adding a coaxial digital output on Sony CDP | rabbitz | Digital Source | 6 | 2nd March 2006 11:57 AM |
| HELP NEEDED: Making coaxial digital output to SONY CDP | cartman | Digital Source | 3 | 31st July 2005 06:58 PM |
| Additional digital output on Teac VRDS players | SisterOfMercy | Digital Source | 35 | 19th July 2003 12:07 AM |
| Page generated in 0.12381 seconds (77.53% PHP - 22.47% MySQL) with 11 queries |
