| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Dear all,
Understand that there is I2S output on the Philips CD PRO2 transport. Is this output active by default and ready for use for direct connection to DAC chip that accepts I2S? Or activation must be done via the DSA control? I have done my search in this forum but there is no clear indication anywhere, please advise and help me. Thank you. |
#2 |
I have the CD-Pro2. The I2S is active at all times by default. Bear in mind that clocking is at 48fs, rather than the (more common) standard 64fs. This will make the unit fundamentally imcompatible with some dacs (Twisted Pear Buffalo as an example).
But with compatible dacs it works very well. Goto |
#3 | |
#4 |
Hi Coomstech,
Where are you in Sing ? Maybe we could might up sometime. Me building the same thing too. |
#5 | |
#6 |
4 hrs apart. I'm actually much closer than you think.
Only problem now is that work commitment has taken a major slice of my time away from my diy projects. |
| a doubt about a circuit | simonwai999 | Parts | 29 | 15th April 2011 09:53 AM |
| supply regularly CD-Pro2 module VAU1254 CD-Pro (VAU1252) CD-Pro2 (VAU1254/11) vam1250 | smartech | Vendor's Bazaar | 1 | 10th April 2011 11:02 AM |
| doubt | swaroopvg | Power Supplies | 0 | 1st July 2006 06:27 PM |
| EAS/ELF doubt | rs1026 | Chip Amps | 8 | 9th November 2004 07:45 PM |
| Page generated in 0.09440 seconds (79.19% PHP - 20.81% MySQL) with 10 queries |
