| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hello All,
After cleaning up my workroom I found a cd624 lying around. It looks great to modify and after reading some old posts I want to give it a try. Just wondering of this modded players are still running and what mod improved the sound most? I quess I will start with the power supply and the analogue output. Maybe someone can help me with a service manual for modding the digital circuit. Best regards, Roelof |
#3 |
Magneto the Gravity Man
There is not a huge amount that can be done to the DAC side of things. This is a fairly early bitstream player.
Adding an extra transformer or 2 to supply the analog side of things would help as would upgrading the existing with schottky diodes and (slightly) larger/better caps. Extra regulators could also be installed for just about every supply line and chip, if you want to go the whole hog. The usual items such as removing the headphone output (easy on this model) and also the muting circuits. Replacing the output opamp, damping the case and CDM, screening the chips with copper foil, fitting a "display Off" switch etc Andy
If it ain't broke, break it !! Then fix it again. It's called DIY ! |
#4 |
Thanks Ebbe for the manual. Just removed the circuitboard out of the housing. Now I can find and trace the components much easier.
Like Andy suggested, I will concentrate on the power regulations and output amp. Maybe I will replace the X-tal for a Tent XO, but first the powersupply. Best regards, Roelof |
#5 |
can anybody upload the philips cd624 service manual for me? I need it to fix my cd player.
#6 |
vubkevin
give me your email |
#7 |
my email : vubkevin at hotmail.com
Thanks : |
| FS Alnico Philips AD3800M AD3800AM and Philips transformers | guglielmope | Swap Meet | 8 | 10th January 2011 11:28 AM |
| Philips CD624 service manual | Stuey | Digital Source | 7 | 20th March 2009 07:49 PM |
| philips cd 880 philips cd880 service manual | 0519 | Digital Source | 4 | 28th August 2008 11:43 AM |
| Philips CD624/634 Manual Service | 2slow4u | Digital Source | 4 | 28th September 2006 10:56 PM |
| CDM 1 by Philips | Kal | Digital Source | 1 | 7th June 2005 10:52 AM |
| Page generated in 0.09356 seconds (70.62% PHP - 29.38% MySQL) with 10 queries |
