Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 29th August 2008, 03:33 PM   #1
Default Digital Volume Contol - CS3318 - MAX5440
Hi all, I'm designing a multi channel volume contol for my 7.1 Power amp. Hoping to use the:
CS3318: http://pdf1.alldatasheet.com/datashe...US/CS3318.html
As master control.
MAX5440: http://datasheets.maxim-ic.com/en/ds/MAX5440.pdf
As balance and indavidual(per 2 channel) volume control.
contolled all with rotary encoders.
Firstly, anyone had any experence with these devices? How do they sound?
Can the CS3318 work well as a preamp? Or do i have to have a seperate stage?
I havnt got a clue on programing a microcontroller to recive grey code and send I2C to the CS3318. Can any one give an example code? I can work with C as i have little knowledge on it and I'm currently learning it. I have a PIC development enviroment and a programmer so i can have a try.
I'll post a block diagram of my idea when I get my scanner installed.
Thanks =].
Old 29th August 2008, 04:49 PM   #2
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
No need to use two chips, the CS3318 can set each channel individually so one chip can do level, individual level offset, balance etc. It's just a matter of setting the individual channels.
On my website you see an example of how this *could* be done. I'm using the SPI interface, but that's not significant.
Audio quality is superb (that's what others tell me too).
Jan Didden
/Another new issue: Linear Audio Volume 3!
Old 30th August 2008, 05:08 PM   #3
I would do as janneman suggests, as the crystal device kicks maxims big time when it comes to the figures of distortion etc.
maxim is focus on components for portable devices but not top-end prestanda.
but soldering the crystal ic... uurh.
listen! Can you hear that ...
Old 30th August 2008, 06:30 PM   #4
Hmm, sounds like a plan. I'll just use the CS. Not too worried about soldering. I've soldered SSOPs and TSSOPs before quite nicely. But I have no clue on the I2C, I've just got to grips with a PIC blinking an LED :S. Any pointers where to get started?
Old 31st August 2008, 09:37 AM   #5
If your PIC has the I2C accessory, using it is pretty straightforward. There's an I2C tutorial here: http://www.winpicprog.co.uk/pic_tutorial.htm
Old 8th June 2011, 01:36 PM   #6
tiefbassuebertr's Avatar
I am looking for kits for such volume control solutions - not a completly preamplifier or integrated amplifier kit, but only the volume control part include remote control transmitter/receiver.
Who can post several proposals?
philips cd 850 mk 2 remote contol homertooties Digital Source 0 27th January 2009 07:56 AM
digital volume pot ic Bengali Digital Source 4 13th March 2007 07:01 PM
Welborne Labs Remote Contol Kit with Display mcdoug88 Swap Meet 2 22nd February 2007 02:21 AM
Multi-Channel Contol Unit Family_Dog Tubes / Valves 10 28th April 2006 10:14 AM
digital volume kozak Chip Amps 2 25th May 2004 12:21 AM
Page generated in 0.08172 seconds (75.81% PHP - 24.19% MySQL) with 10 queries
