Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
it dosnt work!!!(TDA1543)
Old 24th March 2003, 09:42 AM   #1
takashi is offline takashi
Default it dosnt work!!!(TDA1543)
i want to ask some question about TDA1543.
is it only support I2S format?
i use a AD1892 to work with TDA1543, it dosnt work.
then i use CS8414, it work best in I2S mode. but the Analog output of the TDA1543 is too small(about 100mVp-p), and the wave have many high frequency in it.
(i use a 1K hz test CD to do the test.)
i use 1K resistor to connect pin 8 and 7 to GND, the supply voltage is 8V.
please help!
Old 24th March 2003, 10:22 AM   #2
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
TDA1543 is I2S only and when CS8412 or CS8414 is used in the right mode ( 2 ) you should have an outputvoltage of at least 0.7 V. This is with 5 V supply and 3 x 1 k resistors. Try to lower your supply voltage to 6 V and see what happens. Not all TDA1543 like 8V. Tried it but it clipped severely.
BTW did you play the right track for measuring output level ?
Please see this site for correct setting of the I2S mode:
http://www.geocities.com/rjm003.geo/...o/diy_dac.html
It's only audio. Member of the non modular PCB design committee
Old 24th March 2003, 08:35 PM   #3
vuki is offline vuki  Croatia
vuki's Avatar
Have a look at this thread - might help:
http://db.audioasylum.com/cgi/m.pl?f...a1543&session=
also
http://www.diyaudio.com/forums/showt...hlight=tda1543
Old 24th March 2003, 08:51 PM   #4
scottnixon is offline scottnixon
Default Where's pin 6?
Takashi.. you need to load pin 6 (left out) also with a 1k and drop your voltage to 5V if you want to use that value 1k for vref and IV. Vref needs both dac outputs loaded, otherwise it clips severely and is not at all usable. 8V supply requires slightly taller resistors.
Old 25th March 2003, 02:22 PM   #5
fedde is offline fedde  Netherlands
Default Re: Where's pin 6?
What would you suggest using ? I now use my TDA1543 dac with 8V and 3x 1K. The sound is quite ok, though the sound could be more controlled. (I need a buffer)
Thanx,
Fedde
Old 25th March 2003, 02:51 PM   #6
thanks a lot !
it work finally!
i use 2k in pin7
and 4.7k for pin 6 and 8
Old 25th March 2003, 03:10 PM   #7
jean-paul's Avatar
4k7 and no clipping ?!?!?!
Old 25th March 2003, 03:55 PM   #8
rbroer is online now rbroer  Netherlands
rbroer's Avatar
Takashi, what are you doing
You either got a very strange TDA1543 or it is screwed up (can happen btw).
The Riv is way too large (4.7k) to stay within DC voltage compliance of the DAC.
Read the datasheet and you will understand.
You must limit the AC voltage swing to stay within 1.8V and Vsupply-1.2V.
In your case with Vsupply of 8V, your maximum swing is 1.8V to 6.8V, that is 5V.
With an assumed output current of 2.3mA, this results in a maximum Riv of 2k17 (5V/2.3mA).
You need a biascurrent of 0.828mA (1.8V/Riv), so Iref needs to be 0.414mA, resulting in a Rref of 5k31 (2.2V/Ibias/2)
I would advise to select Riv < 2k17 and to use a pot for the bias.
Adjust the pot such that with no music playing the output voltage on pin 6 and 8 is in the middle of your DC voltage compliance range, in your case (8V-1.2V-1.8V)/2 + 1.8V = 4.3V
Rudolf Broertjes
Old 25th March 2003, 04:17 PM   #9
Thank you Rudolf...
I already had the plan to use three potmeters to find the best sounding configuration. This is a new motivation to actually try that
I wonder if it would be beneficial to increase the 100 K resistor after the cap to 200-300 K !? Did you ever drive your passive I/V dacs into amps with an input impedance of 10K-20 K?
Fedde
Old 25th March 2003, 08:25 PM   #10
jean-paul's Avatar
Why ? If you want to change the value you will hear a loud plop when changing interconnects assuming you use big output caps. When a low value is used this won't be a problem but it will not have a great influence on the DAC when you raise the resistance.
You obviously need a buffer / amplifying stage Fedde ! BTW 3 x 1 K is not optimal with 8 V supply voltage as you can calculate with the excellent example Rudolf gave. 3 x 1 k is OK with 5 V supply voltage.
BTW Thank you Rudolf for the very good example. You obviously have the ability to understand Philips datasheets
it dosnt work!!!(TDA1543)Hide this!Advertise here!
Fs Tda1543 stonehome Swap Meet 1 13th February 2008 05:28 PM
Where to buy TDA1543 D/A stan_33 Digital Source 32 7th May 2004 08:54 AM
My first TDA1543 Non O/S DAC r!sc! Digital Source 4 4th April 2004 12:14 PM
TDA1543 dac Rotellian Digital Source 9 12th September 2003 09:38 PM
DIY Non-OS TDA1543 DAC BillyF Digital Source 1 4th August 2003 09:27 AM
