| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#31 |
Banned
It may have low jitter, but I suspect that they are refering to jitter coming off of the disc. Two diferent beasts to deal with.
The methods to reduce sensitivty to jitter on the TX end of the cable is similar to those on the RX side. Not hard, but no one pays attention to it. Speaking of which......a famous audio designer once built a D/A box with a 100 ohm resistor on the input. When I asked him why not 75 ohms, he replied: "Hey, it is a lot closer than no load at all. Which is what most everyone else does. 100 ohms is what we had that day." Or even worse.......a 5-pole LPF. As for internal stuff.......it is possible to build a good clock that is phase locked to the recovered clock with a long time constant. I would expect that such a circuit would need the incoming signal to be within +/- 500 ppm, as it would be hard to pull a decent crystal very far without degrading performance. Jocko |
#32 | |
RonS |
#33 | |
DIY !
Arne K
Ars longa, vita brevis |
#34 | |
A pull range of 500ppm is not feasible, unless you have a very cheap crystal with a low Q or degrade the Q with a small series inductance. It is the very small series resonant capacitance together with the parasitic case capacitance that limits the pull range. Crystals for VXCO’s are therefore usually packed in a glass envelope, ± 100ppm is a more realistic pull range. But ±100ppm is sufficient, the clock of the SPDIF signal coming out of the transport is usually no more than 10 ppm off. For some inspiration read the work of Guido Tent, he already did build a VXCO based PLL clock circuit for a DAC: http://members.chello.nl/~m.heijlige...tml/dactop.htm |
#35 | |
Thanks for refering to our design. And yes, you are right, a pull range of +/- 100 ppm is sufficient, assumed the redbook is followed. We measured nearly always 2.3 - 2.7V at the control pin of the VCXO within the DAC (wehere 0,5 to 4,5 was possible) For those interested, I have designed a module that contains a phase comperator, a slow (1 Hz) PLL and a neat, low jitter VCXO. Jittery clock in, clean clock out ! This module can be used to upgrade external DACs all the best |
#36 | |
Absolutely, if it is universal (in and out formats) and lo jitter. Inside a player is best but I know of no DIY system that has both (player and receiving end of DAC). This will be excellent. There are expensive players (TEAC and Krell) that have lousy digital outputs. |
#37 | |
D2D is too expensive and best on I2S connection. It is mno longer available. Come to think of it , an I2S13W unit for the receiving end of a DAC would be excellent |
#38 |
Banned
I meant 50 ppm, my brain was stuck on a figure around 500 Hz for an 11 MHz crystal.
As for Krell having lousy digital outputs.......yeah, I would believe that. Guido: Do you have a feel for how close the average CDP is with respect to initial frequency accuracy? Just curious. Jocko |
#39 | |
Jitter figures of course are a whole different thing. Eric.
I believe not to believe in any fixed belief system. |
#40 | |
Jocko asked about CDP crystal acuracy, and Eric answered above. My experience: I never saw one out of spec. The worst I sam was about +60 ppm, whereas +/- 100ppm is the redbook spec best regards |
| LM3875 audiosector kit - Optimum DC cable length - power & amp PCBs? | GAH | Chip Amps | 9 | 28th August 2009 04:18 PM |
| Long cable length - SPDIF or analogue? | johnm | Digital Source | 5 | 14th August 2007 09:17 PM |
| AES/EBU coax cables sensitivity to cable length? | miksin | Digital Source | 9 | 15th August 2006 12:16 PM |
| Digital Cable | Jesús Puerto | Digital Source | 0 | 7th September 2003 02:14 PM |
| Page generated in 0.11907 seconds (80.16% PHP - 19.84% MySQL) with 11 queries |
