High-end DAC designs? - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 27th August 2008, 05:30 PM   #11
see the comments below:
http://www.tubecad.com/2006/06/blog0070.htm
regards,
Joo
Old 27th August 2008, 06:54 PM   #12
myhrrhleine's Avatar
What about jitter?
[Grasshopper]:Old man, how is it that you hear these things?
[master]:Young man, how is it that you do not?
Old 28th August 2008, 07:43 AM   #13
AND, don't forget about having a decent clock!
Old 29th August 2008, 04:18 PM   #14
Which clock; TentLabs, Elso Kwak, LCaudio? Any else?
Old 30th August 2008, 07:54 AM   #15
I'm not sure choice of clock is that crucial.
I think its more important that the clock's power supply is very quiet.
I use my own variation of what some call the Kwak Clock, and it works well.
Old 30th August 2008, 08:17 AM   #16
QSerraTico_Tico's Avatar
Hi philpoole, you care to post your version?
Old 30th August 2008, 01:26 PM   #17
Well, its not wildly different.
Essentially its single supply, with a fairly standard regulator and large decoupling capacitors. Nothing special. I thought I'd try it to save space and see if would sound different. I have the bits to have another one, so I can do some much better regulation, and return to dual supply.
The Colpitt's oscillator and comparator circuit are essentially the same.
I have toyed with using one without a comparator - as long as the output is large enough, as it should possible to clock using a sine wave, and then you could avoid any phase errors caused by the comparator switching. Not sure if would yield any benefits.
Which sort of leads me to the point I think I've found. These ideas have never come into fruition as I believe what I have is almost good enough (although I think the regulation could be improved).
Using a seperate clock module is very important, but I think they all do the job relatively well.
I know I sound undecided, but as I already have a clock, I'm more interested in my digital filter setup, as I think improving that will provide more improvement.
Old 26th October 2008, 07:47 PM   #18
Telstar is offline Telstar  Italy
bump for a very interesting conversation.
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 27th October 2008, 05:17 PM   #19
Regarding noise in clock supplies you may find this thread interesting:
http://www.diyhifi.org/forums/viewto...t=1570&start=0
Ultra High-End DAC designs for DIY? steaxauce Digital Line Level 61 27th February 2009 07:54 PM
High End designs? jaholbro20 Multi-Way 3 15th December 2008 04:36 AM
High Efficiency designs? EDDIEMUNSTER Multi-Way 36 9th May 2007 01:55 AM
High Power Coax designs?? Zero Cool Multi-Way 4 14th March 2007 10:12 PM
Copyright 1999-2017 diyAudio
