HDD players with built in PCM1794 DAC
The Aune sounds/looks very interesting for a car application. One question, can you set it to shuffle through the songs? Apparently the similar QA-350 player has this option.
Hello , The newest version of the mini APE is the Aune 32bit S1 HIFI music player , the information please check this :
32 BIT S1 HIFI Digital Music Player
http://http://shop2.hifidiy.net/index.php?main_page=product_info&cPath=10_33&products_id=111
The S1 player is not only a HIFI Music Player , it also can be used as :
•High quality 32BIT/24BIT/16BIT DAC
•High quality digital transport
•High quality headphone amplifier
Highlights
1) Use High quality TI CPU
2) Support 24bit/192K and 32bit music playback
3) With the SD card, USB flash disk as storage medium
4) USB 2.0 OTG ,ESATA , SD Card socket
5) With headphone socket
6) Support APE / FLAC / TTA / Mp3/ WAV/ CUE
7) Remote control Function
6) Support software Upgrade
7) With Network socket , support LAN connection
8) External five core power socket , with power upgrade function
9)AKM4390 DAC inside , support 32BIT
10) One way coaxial output and one way optical digital output
•Main functions
• USB2.0-OTG
USB 2.0 high –speed jack
• eSATA 3gb/s
eSATA high –speed expansion card
• 32BIT High Resolution
Capable of decoding 32BIT digital signal
• HIFI Quality Sound
Designed for HIFI quality sound reproduction
• Multifunction
Multifunctional used with PC audio , home audio and room audio devices
UNPACK
• 32 bit S1 HIFI Digital Music Player
 Five Core Cable
 External Power Unit
 AC power Core
 Remote Control
 User manual
Specification
Frequency response :20-20KHz + - 0.2db
Distortion : 1KHz,2.8Vrms,-90db
Resolution : 106db
0dB output level (Line out )2.8VRMS
SNR(S/N):108db
Headphone amp power at 600 ohm : 2.8VRMS/13mW。
32ohm power :180mW
Dimension (chassis) :160*160*48(mm)
