Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 8th August 2008, 08:05 PM   #1
Ecaroh is offline Ecaroh  United States
Default Lube for transport - need advice
Photos attached of a Philips CDM12.1 mechanism, now replaced with a new VAM1202.
Have seen a variety of suggestions on where to lube and what to use, some using terms I'm not sure of. (E.g., what exactly are the "rails" -- I only seem to detect one rail.)
Places I'm wondering about for lube are marked.
People say oil, but it seems at least on gears it would need to be rather heavy.... Perhaps a light grease not prone to turning into solid gunk?
Many thanks,
Steve
Old 8th August 2008, 09:06 PM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
for gears and side slider - vaseline (plain one , from local drugstore)
for metal rail - light oil , same as for sewing machine
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 9th August 2008, 01:46 PM   #3
Mooly's Avatar
There is only one sure way to do these and that is too fully dismantle. If you are at all unsure don't attempt. It's not difficult but it is fiddly in parts, however in my experience it is the ONLY way to get a lasting job.
You have to remove the large gear carefully -- wash it in iso etc and clean all gunge from the teeth with a piece of stiff card etc. Clean centre hole and metal spindle it fits on. I always remove the metal rail the pickup runs on and clean all old grease from the pickup and also remove the rack gear on the pickup and wash/clean.
Remove sled motor and clean the worm gear carefully.
As to what grease, it has to be compatible with plastic. I always used a special metal/plastics grease made by Electrolube. Vaseline sounds a bit heavy to me. Apply very little to the gears and a give a thin smear on the metal rail. Also the "slider" opposite.
The old grease dosn't just go hard, it seems to crystalise into little hard grains that can cause the gears to jam and the player to skip.
If you try it, be careful and don't smear the lens with grease, it's easily done. The rail is held by little plastic wedges that slide in on top of the rail at the ends. You are best with an old pickup to practise on really.
Good luck and don't break it
Old 9th August 2008, 05:23 PM   #4
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
Molykote EM-30L if you can find it in small quantities. Mentioned in a lot of CD service manuals.
Old 9th August 2008, 07:19 PM   #5
tvi is offline tvi  Australia
tvi's Avatar
Super-lube has worked for me in most applications includig cd mechanisms.
James
The border between the Real and the unreal is not fixed, but just marks the last place where rival gangs of shamans fought each other to a standstill. Robert Anton Wilson
Old 10th August 2008, 06:19 AM   #6
Mooly's Avatar
WWW.CPC.CO.UK Enter part number spg35sl
Old 13th August 2008, 09:41 PM   #7
Calamaro's Avatar
Try Teflon grease (normally used for bikes).
DIY transport w/ CDROM drive vs player as transport dw1narso Digital Source 6 2nd September 2011 05:15 AM
CD: Sony CDP-X777ES transport repair advice requested csrote Digital Source 1 16th September 2008 09:58 AM
Is it just silicon lube? j beede Pass Labs 1 10th January 2008 03:05 AM
petrolatum -aka vaseline- as bearing lube? federico moreno Analogue Source 3 27th June 2007 06:22 PM
Poster in Musical Instrument forum needs bridging advice on BrianGT 4780 advice moving_electron Chip Amps 0 16th February 2005 12:37 AM
Page generated in 0.10168 seconds (75.26% PHP - 24.74% MySQL) with 11 queries
