Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
My USB/COX DAC board
Old 4th August 2008, 11:26 AM   #1
audio-gd is offline audio-gd  China
Default My USB/COX DAC board
I have finished the test of my USB/COX DAC board, it use PCM2707 to decode USB, and DIR9001 to received the COX,
I use a AD1852 to decode the I2S signal, later I will send the circuit diagram, and welcome every body give me advice.
Old 15th August 2008, 08:09 AM   #2
DAC circuit
Old 15th August 2008, 08:12 AM   #3
Power supply
Old 15th August 2008, 09:37 AM   #4
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Default Re: My USB/COX DAC board
Once i built something very similar. Replacing the opamp with a differential mosfet pair, like a Pass preamp was an obvious improvement.
I wish someone will design a usb dac using a better usb chip.
Old 15th August 2008, 10:18 AM   #5
Yes, I have replace the OPA2134 to Discrete OPA
Old 18th May 2011, 06:34 PM   #6
udailey is offline udailey  United States
Passive Aggressive
Do the transistors in the power supply need to be matched or do we get away from that with the trimmer?
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 24th May 2011, 05:46 PM   #7
Passive Aggressive
Hoping someone might have an answer. I etched a board to try this circuit and want to get the best performance but not sure if matching is necessary.
Old 25th May 2011, 01:33 AM   #8
wgxold is offline wgxold  China
Oh, this design is so cool. I want to know the size of the board.
Old 25th May 2011, 01:44 AM   #9
Passive Aggressive
Default board I came up with
This is for the psu on the bottom of his 3 supply schematic. 100mmx146mm
Blue is top layer and green is bottom. When you see green disappear under blue its not the same trace but they are overlapping at that point.
Old 25th May 2011, 01:46 AM   #10
Passive Aggressive
hopefully someone will be interested enough to pop in and talk about transistor matching and if it is necessary on the +/- supply PSU.
I bought 50 of each small signal transistor and 10 of each larger transistor. Hope to not have to match them all, even though its not a real big pain. I imagine DC offset wont be a problem ;P but not sure what that trimmer does and want to make sure it does not make up for only small differences between +/-
My USB/COX DAC boardHide this!Advertise here!
Sure Electronics New Tripath Board 4*100W class-D Amplifier Board 7788q Class D 354 17th March 2017 02:19 PM
Board to board soldering: BGA/SMD style NeoY2k Parts 0 7th December 2008 05:36 PM
My Cambridge 500SE, needs an output board (to replace internal DAC Board) slbender Digital Source 0 15th May 2008 02:36 AM
Lost 1 Zv4 ckt board..looking to buy 1 circuit board Blues Pass Labs 1 22nd March 2004 11:09 PM
Copyright ©1999-2017 diyAudio
