Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 30th July 2008, 05:21 AM   #1
salesmonster's Avatar
Default CD Player with variable outputs
I'm looking for a CD (or DVD) player for an audio-only system. The player will feed directly into a power amp. Sound quality doesn't have to be stellar - it's for a non-audiophile's exercise room. Any suggestions of a readily available model, either new or used?
SM
Old 30th July 2008, 06:33 AM   #2
amc184 is offline amc184  New Zealand
amc184's Avatar
There are lots of player out there that have a built in volume control, probably too many to list. But anyway, I have a Yamaha CDC-655 CD changer that has this facility.
Anton
Old 30th July 2008, 06:43 AM   #3
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Marantz CD63, CD73
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 30th July 2008, 12:51 PM   #4
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
Just be aware that a lot of CD players such as the CD63 go back to maximum volume when powering on. Try and find one with a pot or doesn't default back to maximum volume.
Could save your speakers or ears.
Old 30th July 2008, 11:16 PM   #5
amc184's Avatar
Thats quite a bad characteristic, I could imagine being caught out by that. My Yamaha doesn't, it turns on to the same volume level as you left it.
Old 31st July 2008, 04:11 PM   #6
rabbitz's Avatar
Would be very easy to get caught.
All the Sonys and a Shanling I have all startup with the volume where you left it. All those have a pot. I did have a Sony that did it in the digital domain but can't remember if it defaulted back to maximum volume.
Old 31st July 2008, 05:05 PM   #7
poynton's Avatar
Marantz CD60 has a motorised pot. and TDA1541A
"A standard CD player outputs signal at 24V" wwenze Digital Source 16 13th July 2009 04:50 PM
Annoying static on analogue outputs of CD player azl Digital Source 6 29th May 2009 07:41 AM
Balanced outputs used as inverting & Non-inverting preamplier outputs gni Solid State 4 19th September 2008 03:25 AM
Double variable outputs for BOSOZ gchrist Pass Labs 10 20th January 2008 03:38 PM
Excessive output voltage from cd player outputs percy Everything Else 2 26th March 2006 10:30 AM
Page generated in 0.08516 seconds (74.13% PHP - 25.87% MySQL) with 10 queries
