| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#31 |
thanx.
#32 |
this is off topic, but while i've got jocko's and fred's attention...
have you guys heard of this ERS material? i mention it in another thread... carbon fibre fabric impregnated with strands of metal alloys... supposedly derived from military stealth/diplomatic quiet-room applications. have you encountered this in the telecom industry? |
#33 |
Well, as far as i know the SACDs of Sony use a 45MHz clock.
45MHz is a bit much for standard HC logic, isn´t it? I have replaced it in my Sony DAC to a VHC inverter and sound became definately better - no doubt! It is fed with 49.125 MHz
If time permits - stuff some parsley in your ears and listen how it grows! |
#34 |
diyAudio Retiree
"Interesting that after AC logic was introduced, a whole new class of CMOS with faster edge rates than HC CMOS but addressing the shortcomings of AC CMOS"
And VHC is one of those families. I notice you didn't use AC CMOS. |
#35 |
I think rbroer has a point afterall:
Typical PLL stops working on a quite high freq due to that the receiver chip needs to have a sufficient capture range. Mechanical feedback when playing loud would most certenly come into play. By freeing the osc from the chassis, the frequency which would influence the osc will rise considerally and maybe end up within the PLL (>1 khz?) range and thus filter out the contribution from mechanical feedback. / |
| What crystal is this?? | calvinhpk | Digital Source | 4 | 24th August 2009 03:08 PM |
| What crystal is these? | calvinhpk | Parts | 6 | 24th August 2009 07:35 AM |
| let's tweak this amp!!!!! | Flavio88 | Solid State | 34 | 14th August 2006 06:50 AM |
| Can the 5V in the T-amp be tweak? | ChuckT | Class D | 0 | 13th October 2005 09:25 AM |
| new tweak? | mirlo | Everything Else | 1 | 21st May 2004 11:02 PM |
| Page generated in 0.09524 seconds (76.56% PHP - 23.44% MySQL) with 10 queries |
