Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Need help for Philips CD104
Old 18th July 2008, 08:33 PM   #1
dubai2000 is offline dubai2000  Europe
Default Need help for Philips CD104
Hi all,
I have been lurking around here for some time, but as I am a newbie to DIY it has been basically to 'learn'.
Well, having recaped (and slightly tweaked) my first CD player recently, I decided to have a go at the Philips.
All went well - or so I hope - until I damaged an SMD cap on the board just underneath the clock. Now I was wondering if somebody could tell me which value this cap had so that I can replace it.
I should mention that I downloaded a service manual but I have to admit that I am not skilled enough to read the schematic properly to identify the damaged part.
Any help will be greatly appreciated.
All the best from rainy Germany,
Wolfram
Old 18th July 2008, 09:00 PM   #2
es44 is offline es44  Denmark
es44's Avatar
Admitted, i don't have any experience with the cd104, but i've seen this thread CD104 Tweaks
I'm sure there's a lot of people with knowledge about this player.
Best regards
Ebbe
Old 18th July 2008, 09:26 PM   #3
Here should be some pics of the board now.
Old 18th July 2008, 09:26 PM   #4
Number two:
Old 18th July 2008, 10:15 PM   #5
simonov is offline simonov  Bulgaria
simonov's Avatar
The picture showing the smd cap is too close. Make a bit zoom out
Old 18th July 2008, 11:31 PM   #6
Better?
The 'antennas' are the uncut legs of the new 22F cap and the legs on the very right belong to the SAA7020
Old 19th July 2008, 12:00 AM   #7
Jogi is offline Jogi  Germany
Hi Wolfram,
do I know you somewhere?
Looks like a bypass for the bigger Antennas, no problem to just leave it out.
For better feelings you could solder a Wima MKS2 0,22 at this place, if at hand
But it should work fine without, if no other bug is hidden somewhere in the wilderness of the PCB...
Best regards from cologne,
Juergen
p.S. NONOS rulez!
Old 19th July 2008, 12:15 AM   #8
rtirion is offline rtirion
The 22uF is c2513. The broken smd C is a 22n bypass/decouple
cap c2539.
If the new c2513 is a low esr type you just might remove all
the remains of c2539 and give it a try. If you need to replace
the smd C, find a nice 22n smd and put it in place.
Hope this helps.
Old 19th July 2008, 12:48 AM   #9
Thanks a lot guys!
Well, Jogi, the world is rather small these days..... ....and be happy that your latest toy does without that SMD stuff....to avoid a harsher word
Greetings from rainy Germany,
Wolfram
Old 19th July 2008, 07:54 PM   #10
Well, tried to put all boards into the frame again - switched on and....nothing, just a blown fuse .
So any suggestions what I should be looking at?
Greetings from Germany,
Wolfram
Need help for Philips CD104Hide this!Advertise here!
Philips CD104 problems brianuk Digital Source 20 22nd April 2008 03:10 PM
Philips CD104 divad68 Digital Source 3 30th October 2006 08:46 PM
Philips CD104 parrjohn Digital Source 10 12th June 2005 09:41 PM
Philips Cd104 Schematics chlo Digital Source 0 28th May 2005 01:22 PM
Philips CD104 Bob Roberts Digital Source 14 24th September 2004 04:25 PM
Copyright ©1999-2017 diyAudio
