Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Rotel rcd951 need help troubleshooting
Old 16th July 2008, 08:24 PM   #1
fastvideo is offline fastvideo  Canada
Default Rotel rcd951 need help troubleshooting
No problem loading or eject cds, spindle motor just turn a bit and stop.
Replaced new laser unit, laser light doesn't turn on, lens does move up and down, no rf signal output.
No disc shown on display.
Old 17th July 2008, 08:07 AM   #2
Mooly's Avatar
Whats the pickup -- KSSxxx type ? Did you unsolder the shorting link on it (solder blob ).
Old 17th July 2008, 12:27 PM   #3
KSS-213B, the shorted link was unsolder.
Anyone has a service manual ?
I am using sony cdp-c260 manual that I found from this forum as a reference, they use the same servo and rf amp circuitry.
Old 17th July 2008, 12:44 PM   #4
Mooly's Avatar
Are you 100% sure the laser is not lit. It will only light during "focus search" and they can be hard to see. DO NOT LOOK DIRECTLY and no closer than 12 inches. 95% of the energy is in the infra red. Is the spindle motor OK. Try unsoldering it and running it from PP3 battery for a few seconds each way to clean up the commutator.
Old 17th July 2008, 02:41 PM   #5
Just spent an hour on it.
Laser doesn't light up.
This is a new laser deck unit.
laser is fine, tested it manually.
Possible the RF amp is defective?? Rare!!!
Old 17th July 2008, 06:03 PM   #6
Mooly's Avatar
Very rare -- yes. It's not a CX20108 is it ? no they must be too old. Dare I even ask how you tested the laser manually A faulty laser can still light with enough current, but it just behaves like a side emmiting LED with no lasing action.
When you say Laser Deck unit do you mean all the chassis -- motors and all ?
Can you measure any laser current, there is often a resistor you can measure the volt drop over and calculate. The last three digits of the serial number on the pickup give the current in milliamps for example xxxxxxxx476 would be 47.6 milliamps.
Old 17th July 2008, 08:22 PM   #7
Yes, all chasis.
RF amp is CXA1821M
Old 17th July 2008, 08:28 PM   #8
anatech is offline anatech  Canada
anatech's Avatar
Hi fastvideo,
Absolutely, measure the laser current. Also monitor the F OK signal if you can. That indicates a focus lock.
If your RF amp is defective, then your old head assy should be okay. A new transport may not always be good. I have seen the turntable height off. That will sometimes prevent the spindle from turning, or at least prevent a focus lock.
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 18th July 2008, 02:50 AM   #9
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Have you check the flat cable connect from the laser pick-up to the pcb???
Old 18th July 2008, 04:22 AM   #10
Yes, I have checked the flat cable. No cracks.
Same voltage reading at both ends.
CXA1821M
Page 8, get no voltage at collector.
Rotel rcd951 need help troubleshootingHide this!Advertise here!
Troubleshooting a Rotel RA-931 amp/finding replacement parts lars667 Solid State 4 6th April 2013 05:11 PM
Rotel RCD951 mod need help fastvideo Digital Source 3 29th June 2009 01:57 AM
Rotel RCD951 CD player service manual tubenut Digital Source 11 19th April 2008 01:06 PM
Laser type on Rotel RCD951? tubenut Digital Source 2 2nd December 2004 06:17 AM
A clear winner? CD63SE/RCD951/Alpha 7se lazyfly Digital Source 5 8th October 2004 09:06 PM
