Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Rotel rcd951 need help troubleshooting
Old 19th July 2008, 07:50 PM   #21
anatech is online now anatech  Canada
anatech's Avatar
Hi Mooly,
Howdy!
I agree. I think the faults have become magnified and we are now dealing with more than one fault now. Your idea to test the laser circuit is a good one.
There is little hope of figuring this out over the internet. The unit needs to be in front of another set of eyes. A common problem when troubleshooting something that has "you" stuck.
Hi fastvideo,
You have two options I think. One is to leave the unit aside for a week or so, then approach it as a new case. Imagine it's been to another shop first. Then you start from square one and forget everything you think you know about it. Keep an open mind and try not to focus too quickly. The last option would be to have another good audio technician look at this on their own bench.
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 20th July 2008, 03:38 AM   #22
fastvideo is offline fastvideo  Canada
Originally posted by Mooly
I do know you will kick yourself when you find the fault. The laser has to light first whether or not there is any other problem.
Can I ask, did the player just fail "naturally" in use or has it a history
Edit, Have looked again at the data sheet just to confirm this is a totally "analogue device" -- no data lines, clock pulses, I2C --- anything. It's got to work as it is, nothing external can influence it. Pin 19 is active high meaning it should be tied to 5 volts to permanently enable the laser. It's has to work -- it's something silly this !!!
Just wondering where is the 16mhz signal coming from with the working sony.
I got this unit from a store which I am as their repair technician now as a scrap that the old tech could not fix it. It is very well make and have HDCD function with it, well worth for me to spend the time to get it fix.
Hi fastvideo,
-Chris
I have this unit over 9 months. This is my 6 attempt to fix it. No rush but really need others fresh opinion.
Will keep this up with the working sony to campare.
Old 20th July 2008, 04:31 AM   #23
anatech's Avatar
Hi fastvideo,
Clock signal.
You are repeating the same errors in that case. Re-read the responses you have in this thread. You should find the answer in there somewhere. Note that most of what I have said addresses the act of troubleshooting.
Fresh eyes or a fresh approach is required. I wish you luck either way.
-Chris
Old 20th July 2008, 07:59 AM   #24
Mooly's Avatar
Well -- final thoughts -- this is what I would do. Solder a good tag on the ground around the IC so you can permanently connect your meter and 'scope -- there is nothing worse than having one eye on the DVM and trying to poke around with two hands.
Go around EVERY pin on that IC. Does each pin electrically go where it should -- don't just look - measure on low ohms -- could be a hairline crack etc. And measure the volts on each pin, not with a DVM use the 'scope on DC, it's much more revealing showing noise etc. Resolder that shorting link and measure each track on ohms from the pickup to the IC.
If you are still getting nowhere, REMOVE the PNP transistor and solder a 10k (anything between 4k7 and 100k ) between base and emmiter. Now measure again pin 1 both with pin 19 held high and again with it re-connected normally during focus search.
Is it still stuck high ? Lift pin 1 at the IC if so and measure again on the floating pin ? Just had a thought -- connect LED and resistor from collector to ground anyway during testing. Use a bright LED and say a 2K2. That shouldn't upset anything. Remember to unsolder the link again.
Keep us all updated
Old 20th July 2008, 07:12 PM   #25
anatech's Avatar
Hi Mooly,
One thing to add to that. Take notes at each step fastvideo.
-Chris
Rotel rcd951 need help troubleshootingHide this!Advertise here!
Troubleshooting a Rotel RA-931 amp/finding replacement parts lars667 Solid State 4 6th April 2013 05:11 PM
Rotel RCD951 mod need help fastvideo Digital Source 3 29th June 2009 01:57 AM
Rotel RCD951 CD player service manual tubenut Digital Source 11 19th April 2008 01:06 PM
Laser type on Rotel RCD951? tubenut Digital Source 2 2nd December 2004 06:17 AM
A clear winner? CD63SE/RCD951/Alpha 7se lazyfly Digital Source 5 8th October 2004 09:06 PM
Copyright ©1999-2017 diyAudio
