Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 16th July 2008, 01:52 AM   #1
Default rotel rcd-930ax service manual
Hi i have a Rotel RCD 930RX i need a service manual, the player plays and initialize the cds but every 5-15sec. the player
"jump" he shortly abort the replay.
I have already cleand the lens but with no result.
Can somone help me.
Old 16th July 2008, 06:38 AM   #2
Mooly's Avatar
What's the type of laser unit fitted? A fault like this is just as likely to be mechanical, e.g. a sticking sled or faulty spindle motor. You really need to 'scope the R.F. signal coming off the disc to make a more informed judgement.
Old 16th July 2008, 01:10 PM   #3
The laserunit is a kss-210a
Old 16th July 2008, 01:31 PM   #4
Mooly's Avatar
Erm 50 - 50 really. The 210 is cheap enough ( I have replaced many of these, well into 3 figures ). Spindle motors can give trouble (The one the disc sits on), so try this. Unsolder both wires to motor -- quickly don't overheat the terminals -- and run the motor with a PP3 9volt battery for 5 secs or so each way. This helps clean the commutator. Worth trying. Make sure the pickup is free to move and the gears are clean. Then fit a new pickup. Remember they come with a blob of solder shorting the laser to protect it so this needs removing once fitted. It should work out of the box -- no adjustments -- but obviously it's better if you have a scope so you can see whats going on.
Service Manual/ schematic for Rotel ROTEL RHCD-10 Michi CD player Staykov Digital Source 5 16th May 2012 12:24 AM
Looking For Service Manual for Rotel RB990BX dtm1962 Solid State 9 12th January 2012 10:25 AM
Rotel RCD-850 Service Manual Rodmunch Digital Source 5 20th June 2008 05:12 PM
Service manual for Rotel or CDM johnm Digital Source 3 20th November 2006 12:00 PM
Page generated in 0.07979 seconds (71.59% PHP - 28.41% MySQL) with 10 queries
