| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Steve D or anyone:
The new Behringer DCX 2496 handles crossovers (your choice of type) up to 3 way, and up to 4th order LR, in the digital mode, for USD $350-440. It also allows stereo parametric EQ. Behringer advised me that if used for 3 way crossovers, and both 24 dB/ octave LR, "you should have approx 17% processing power free. Each EQ band needs approx 3-4% of the DSP power". They’ve confirmed that this option (24 dB/ octave) would allow each channel _just_ 2 bands of parametric EQ. (Minimum EQ bandwidth is 1/10 oct). There may be an upgrade where you can choose the sample rate between 48 and 96 kHz. 48 kHz gives more space on the dsp power.. but they can’t say when or if it will come out. Does the dbx Driverack PA, or another similar product, when used for 24 dB/ octave, allow more bands of parametric EQ? |
#2 |
The driverack PA has eq only on the input I think, but anyway it sounds terrible in my opinion.
If you need post crossover EQ in one box I'd go for the Rane RPM 26z - you can freely configure where do you wnat the EQ - or the older EV Merlin ISP-100, if you can get it. |
#3 |
hi,
I am using a deq2496 to feed the dcx 2496,4 way setup with sub |
| berhinger t1953 burr brown upgrade | napalm09 | Introductions | 1 | 24th January 2009 07:20 PM |
| A couple of questions re: bi/tri amping, electronic crossovers | EmergencyDpt | Multi-Way | 17 | 21st December 2008 09:18 PM |
| PL-41 and MMF2 combined? | pjanda1 | Analogue Source | 0 | 28th January 2007 03:41 PM |
| Combined PFC AC/DC & DC/DC SMPS | ChocoHolic | Power Supplies | 33 | 22nd December 2005 10:04 PM |
| Available EQ on combined electronic crossovers/ EQ: Berhinger, dbx, etc | rick57 | Multi-Way | 10 | 11th June 2003 10:59 PM |
| Page generated in 0.07796 seconds (71.99% PHP - 28.01% MySQL) with 10 queries |
