Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
CCS Load for 1541A?
CCS Load for 1541A?
Old 13th July 2008, 11:58 PM   #11
kevinkr's Avatar
CCS Load for 1541A?
The key is pin 5.. This is definitely not a recommended approach by the manufacturer of the chip, but it does apparently work.. Someone obviously spent some time figuring this out. Still the commercial applications I have seen using it as an I/V use the conventional transimpedance configuration - for audio I assume the theoretical loss of accuracy is an acceptable trade off for running it open loop. It probably sounds fine, I haven't tried it so I can't say. Seems easier than a fully discrete implementation which is what it emulates. Might be worth trying.
I'm not a fan of the TDA1541 so I don't follow those threads - I may have missed something.
Note that if a vendor decides to clone the AD844 under license down the road or Analog changes internal design details it is possible that this circuit may no longer work with newer chips. Just one of the risks of using a chip in ways not intended by the manufacturer and I've been burned this way... For DIY this probably does not matter.
FWIW this obviously will not work with most op-amps..
I'd say this is pretty clever and I will read the other threads to understand it better.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
CCS Load for 1541A?Hide this!Advertise here!
Power load, dummy load (pic) luka Power Supplies 43 9th February 2012 02:50 PM
Dynamic load line analysis using music and speaker load Michael Koster Tubes / Valves 0 7th March 2008 08:47 PM
TDA 1541a S1 Praudio Swap Meet 2 5th October 2003 05:23 AM
6x TDA 1541A S1 frenzic Digital Source 7 28th August 2003 07:53 PM
