and this circuit - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 18th March 2003, 03:23 PM   #1
Default and this circuit
and this
Old 19th March 2003, 01:29 PM   #2
Jiiim's Avatar
yeah - it could have metastability issues.
Jim.
Old 19th March 2003, 01:39 PM   #3
Jiiim's Avatar
Solution to metastability issues:
Use the other flip-flop(FF) that you have on that IC.
Connect the Q output of the first FF to the D input of the second.
Take the Q output of the second FF and use this as the output.
Connect your clock signal to the clock input on both of the FF's.
This is a standard anti-metastability circuit.
Jim.
Old 17th June 2003, 12:15 PM   #4
Send a message via ICQ to leo529
Default AES out
hi, how to connect this circuit to AES out? thank you
Old 17th June 2003, 12:54 PM   #5
It is interesting to see that meta-stability and the standard cure
against it seems to be quite well-known. When I worked with
digital design professionally almost 20 years ago it was a
largely unknown phenomenon. I remeber learning about it
from an AMD TTL databook/app.note/whatever which described
the phenomenon and claimed that AMD flip-flop were less
susceptible to this by having a much narrower time window
during which the input must not change.
Of course, coping with meta-stability is necessary in these
applications.
Circuit help jetbat Tubes / Valves 16 11th May 2009 04:23 AM
6c4 pre-amp circuit dito Tubes / Valves 2 2nd January 2007 07:42 PM
amp circuit help scott3292 Solid State 10 11th July 2005 11:16 PM
Trouble with speaker protection circuit (Randy Slone's circuit) whalefat Solid State 3 13th April 2005 10:13 AM
What circuit? palesha Solid State 1 24th November 2002 10:18 PM
Copyright 1999-2017 diyAudio
