Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 24th June 2008, 02:32 PM   #1
Default Philips CD-951: Tent Labs XO3 and SPDIF reclock plus I2S out
Dear All DIYAudio members:
Anyone have experience on modification on Philips CD950/951 with Tent's XO3, or similar machine, any help and advise would be welcome!
I have a Tent's XO3 Module with reclock option, as the manual of XO3 mentioned, the SPDIF data out should be taken out from Pin 32 of SAA7310GP (http://www.tentlabs.com/Components/X...23mounting.pdf), indicated as HFI of Data Slicer, as other information come across about SAA7310GP, SAA7310GP have no SPDIF out, the SPDIF should be handle by PCF2705, converting I2S from SAA7310 into SPDIF format, and output at Pin 13 of PCF2705.
So where should I extract the SPDIF for re-clcok in of XO3?
and I want to take I2S data out from the CD-951, instead of wiring at Pin 2,3,4 of SAA7310GP, can I extract the I2S from Pin 1,2,3 of PCF2705? Can I do this??
I hope Guido can see this post, I have a hard time to get advise from him.
Thank you for reading.
Old 29th June 2008, 05:46 AM   #2
Please offer some help, please~~
Old 29th June 2008, 08:38 AM   #3
I have a CD940, which I've worked on, and a CD950 for spares. The two models are quite similar. The main difference is the CD940 has more surface mount stuff.
To confirm as I'm working from memory, I haven't actually checked, the PCF2705 is the 14 or 16 pin DIL chip that is fed I2S from the decoder chip and provides the SPDIF output? I think its that one.
Do you want to reclock the I2S on its way to the onboard DAC? If so then this might not be what you want. If you're sniffing off I2S to feed a seperate DAC, then this is the easiest place to do it.
However, if you're reclocking I2S for the onboard DAC, then you'll need to do it after the digital filter, just before the DAC as the filter can add noise and jitter to the I2S signal. Mind you, I've no experience of reclocking a bitstream DAC.
(I sniff off the I2S before it arrives at the SPDIF encoder and use it to feed a seperate DAC, and I've disabled the power to all stages after the decoder, so the player is essentially a transport for me.)
Phil
Old 29th June 2008, 07:42 PM   #4
Dear Phil:
Thanks for your reply, I have 2 aims this time.
1. Re-clock the SPDIF stream by XO3 board for DAC.
I can't really find the SPDIF out pin from SAA7310 datasheet, but Guido manual stated it's Pin 32 of SPDIF, where is correct place to get SPDIF stream for re-clock?
2. Wired the I2S out of the player for external DAC, it's not thing to do with reclock, I feel soldering on DIL chip is more secure than on the SMD chip.
Old 29th June 2008, 11:09 PM   #5
georgehifi's Avatar
Send a message via MSN to georgehifi
Check the pinouts your self as the SAA7310 has two packages with different pinouts (40pin & 44pin). also Guido relies on emailed info from other techs for some of these pinout and cannot be assumed to be always 100% accurate, I also found one that was wrong a year or so ago.
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 30th June 2008, 02:19 AM   #6
Cheers George
There are SAA7310GP(44 pin QFP) and SAA7310P (40-pin DIL), in Guido manual, no package is indicated, but most SAA7310 found in player is SAA7310GP, so Pin-32 of QFP package called HFI in/out of data slicer, for Pin-32 of DIL package, it's DEEM from Debounce Circuit, none of them looked like SPDIF out, and this player more like using PCF2705 for I2S to SPDIF conversion, and SPDIF out can be found at Pin 13 ( DOBM) of PCF2705, but it's not match with Guido Manual, so I'm not sure which one is correct.
Old 30th June 2008, 07:22 AM   #7
Sorry, I didn't answer your question fully. I nearly did, but editing removed some of the information.
The PCF2705 is ideal for sniffing off both I2S and SPDIF. You'll probably need to lift the leg for the SPDIF output, as you want to reclock and then continue the signal to the output.
The SAA7310 is not used on this player to provide SPDIF output.
Old 30th June 2008, 08:58 AM   #8
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Sorry, can't help here, but just to let anyone know I have a spare CD951, unmodified, and a Tentclock for sale if needed.
Jan Didden
Old 30th June 2008, 12:42 PM   #9
Thank you Phil!! I will try to work on PCF2705 tonight!
Old 30th June 2008, 07:47 PM   #10
Hi
The PCF puts out SPDIF, I have the pinout at my lab, will check tomorrow
Guido Tent
www.Tentlabs.com
Philips Cd-Pro2 player/transport w/ tent labs XO3 clock - $1000 o.b.o. Julien_M Swap Meet 5 25th January 2009 12:03 AM
FS:XO3 Tent labs 27mhz Ryssen Swap Meet 2 19th December 2008 06:21 PM
troubles ordering at tent-labs electrosound Digital Line Level 4 16th November 2008 09:48 PM
tent labs PSU for philips 963sa cporada Digital Source 3 27th April 2006 02:43 PM
Tent Labs XO3 Clock Impessions georgehifi Digital Source 63 9th March 2006 09:08 AM
Page generated in 0.10402 seconds (81.01% PHP - 18.99% MySQL) with 11 queries
