Optical output to Coaxial? - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 18th June 2008, 12:27 AM   #11
rossl is offline rossl  United States
rossl's Avatar
It probably doesn't matter. Your CS8420 can receive a differential input voltage of 200 mV minimum and maximum of VCC, 5 volts.
The coupling cap won't hurt. You may not need it. You can try it with and without. 0.22 uF will work fine.
Old 18th June 2008, 02:34 AM   #12
Tenson is offline Tenson  United Kingdom
Thanks for your replies.
You are of course right that the DAC can handle qite a wide range, but if the output was only 1V to start with I don't want to put it through a voltage divider.
However, I looked at the datasheet for the Toshiba TX176 optical transmitter and it has a lower limit of 2v for its input, so the signal must be 5v or 3v. Adding the voltage divider posted above should bring that in to a safe level for the majority of DACs.
Old 18th June 2008, 10:14 PM   #13
Thanks guys, all sorted
I wrote up what I did so the other Cyrus owners can do the same if they want.
http://www.rdhworld.co.uk/punbb/viewtopic.php?id=9948
Old 18th June 2008, 10:53 PM   #14
rossl's Avatar
good job !
Jambo DAC - DIY USB/Optical/Coaxial DAC kit now available! Jambo Digital Source 8 20th August 2008 09:41 AM
optical coaxial connection mhtplsh Solid State 1 17th May 2008 01:16 AM
optical out to coaxial wooddragon Digital Source 1 12th January 2006 07:49 PM
Optical, Coaxial, and RCA TheDriver41 Digital Source 11 24th January 2005 10:38 PM
Optical vs Coaxial output gchrist Digital Source 15 11th February 2004 05:53 AM
Copyright 1999-2017 diyAudio
