Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
I started my new Tube DAC
Old 29th March 2005, 12:50 PM   #91
Algar_emi is offline Algar_emi  Canada
Algar_emi's Avatar
This the completed bottom module. The big toroidal is the HV supply with electrostatic shield. Then, I modified the Tube section to accept 6N1P tube and the filament section of the transfo had not enough current for this tube. So I added an separate Hammond filament transfo. There also a small Hammond choke for the HV CLC filter. They are all mounted just under the HV supply, so the wires are kept to their minimum. The transfos are mounted using a bitumen and neoprene sandwich to reduce vibrations.
On the back we can see the AC input module with EMI filter and Power On switch.
On the front we can see the blue Power-On led and HV switch mounted inside the small 3/8 bar. There is also two small insulated standoffs used to connect both transfo L-N supply lines.
The wire clamps keep the wires nicely routed
Old 29th March 2005, 01:47 PM   #92
gmarsh is offline gmarsh  Canada
gmarsh's Avatar
Nice project!
Question though - who made that 4-layer PCB?
I'm about to order a 4-layer 16x10cm board for a headphone DAC project, and I was thinking of using a 'no touch' Sierra Proto Express board ($102 USD for two, +customs/shipping/etc)
If there's an inexpensive shop north of the border, I'd love to know about it...
Old 30th March 2005, 03:21 AM   #93
Algar_emi's Avatar
Sorry, I bought it directly from Guido Tent. Very nice PCB indeed.
Old 30th March 2005, 03:04 PM   #94
pedro is offline pedro  Spain
Hi Algar!
Big congratulations!
You are a master.
Would you post the whole work when finished?
pedro
Old 3rd May 2005, 06:04 PM   #95
Algar_emi's Avatar
Default Finally some sound
After months of delays, I finally start to listen to some nice music coming from my Super DAC
I just completed the interconnection of all the PCB and the sound is superb.
The only part missing is the solid stage amp section. I'm planning to rework the class-A Op-amp as my NOS 1545 DAC using FET's biais. This is not really a big miss because I included mainly the solid state section to demonstrate the much superior tube section sound in the first place, and to do some experiment.
I also included the space to mount two small SMD diamond buffer pcb's to be able to install a volume control and be able to use the DAC without preamp if I wish. See this site for the detail on the diamond buffer. Thanks Pedro for this info:
http://home.swipnet.se/~w-50719/hifi/qrv05/index.html
I had to rework the tube section to have the tube mounted horizontally, so I can close the top cover. Here some details of the tube section assy. You can see the rectifier tube with a small heatsink on top and the filament 6.3V LM317 regulator mounted directly on the frame for heat dissipation.
The amp tube pass trought the central metal cross member that then act as a heatsink, see next post...
Old 3rd May 2005, 06:11 PM   #96
Algar_emi's Avatar
Here the amp tube mounting details from back to front of the case central spine. Some holes were drilled around the tube to help heat dissipation. Nitril rings help controlling microphony.
Old 3rd May 2005, 06:13 PM   #97
Algar_emi's Avatar
Here the complete front panel view with the two modules.
Old 3rd May 2005, 06:15 PM   #98
Algar_emi's Avatar
And the complete top view (without the op-amp section, the diamond buffer and volume pot (future options)).
Old 3rd May 2005, 06:16 PM   #99
Algar_emi's Avatar
And the complete top view without the op-amp section, and the future options of the diamond buffers and volume pot.
Remark the short lenght of real and low loss 75 ohms coax coming from the back routing the digital signal. It connects to a real 75 ohms panel mount coax union adapter.
Old 4th May 2005, 01:18 PM   #100
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Originally posted by pedro
Peranders has been totally helpful on teaching me how to adjust his buffer for this particular case (the tube dac).
Just in case some of you has got same problem than I, the "diamond buffer" solution is really a very good one.
Thanks a lot peranders
That's only the normal I.... .... Thanks!
From what I remember you have been the most difficult case in interfacing the buffer right. I'm glad we worked it out finally. Tube outputs are a bit special becasue their rather high output impedance.
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 69 pcb's in order. 65 paid.
I started my new Tube DACHide this!Advertise here!
help me get started Higbean Tubes / Valves 3 1st August 2007 03:09 AM
Getting started Mark245 Solid State 4 20th May 2006 08:05 AM
Getting started with tube preamps Redemption Tubes / Valves 10 4th January 2004 12:16 AM
And this is how it all started Peter Daniel Solid State 36 12th March 2003 10:27 PM
What got you started? Vivek Everything Else 15 7th August 2002 06:45 AM
