Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Suspension rubber for CDM12.x
Old 14th July 2009, 12:14 AM   #11
butternutaud is offline butternutaud  United States
Hi Martin,
Thanks for the tip. I used to own the only audio repair shop in the area. So to my knowledge there are none left in Vermont. I was hoping to be able to buy a dozen or so as I still occassionaly do some CD repairs w/ the Philips assembly.
Old 11th January 2012, 03:32 PM   #12
Mi5ke is offline Mi5ke  United Kingdom
Default How to remove CMD12.x without destroying the rubber mounts?
Does anybody know the "correct" way to remove a CDM12.x without destroying the rubber suspension mounts?
On my player (Cyrus dAD3 S24) the slots for the rubber on the CDM open in the opposite direction to those on the player body, so seems impossible to remove the feet - other than by brute force.
Any ideas? Thanks!
Old 12th January 2012, 08:28 AM   #13
Mooly's Avatar
Easy (if this is what you mean)... you use a small jewellers screwdriver and just push/prise the mounts away from the CDM12 body in a horizontal direction. You are pushing against the barbs in the CDM frame but the mounts slide out easily if you apply enough controlled force.
I have worked on many of these and never damaged or split one.
If you mean removing the "other end" then again, you use a small screwdriver and very carefully work one end of the bush into the slot it's pushed through. Then do the other side of the bush. They are very compressible and will go through the chassis slot. Be careful not to stab them or puncture them but they are pretty tough I find.
Old 31st January 2012, 02:08 PM   #14
Thanks - tried to ease it out, with controlled force, but it just wouldn't go (also quite awkward to get a tool into the right position). Finally, knowing that I was replacing the CDM12.4 anyway, I didn't mind damaging the old non-working unit, so just snipped the plastic a little, and cracked the CDM's retaining tab off (gulp!), thus guaranteeing that the rubber mounts were in perfect condition, unstressed. And everything is fine.... now I just have to figure out where the white nylon drawer-switch cam mechanism goes - not obvious, after it fell out!
Suspension rubber for CDM12.xHide this!Advertise here!
FS - VFD for CDM12 Pro kit vt4c Swap Meet 0 26th May 2009 10:11 AM
fs3 suspension phildcamp Subwoofers 4 29th October 2008 12:29 PM
Cdm12 cac liu Digital Source 1 24th March 2007 11:11 AM
Philips CDM12.10 dsmkwan Digital Source 12 10th May 2006 09:42 PM
Steinmusic cdm12.1 Brownlow Digital Source 15 10th December 2002 10:06 AM
Copyright ©1999-2017 diyAudio
