Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 6th June 2008, 11:57 AM   #1
gmarsh is offline gmarsh  Canada
gmarsh's Avatar
Default DSD / 1-bit input DAC?
I'm designing a board around an Atmel AP7000 processor, which has a "audio bitstream DAC" built into it. Basically, it outputs a pair of 1-bit signals at 128Fs (5.6448M @ 44.1) along with a clock. Sort of like DSD but twice the data rate.
I hope to use this for a diagnostic headphone jack. The quality doesn't have to be that great, but it can't be ridiculously bad (buzzing/supply noise/etc) that can make someone think that something is wrong with the application.
On the cheap side, I could take these lines directly, feed them through a 74xx CMOS gate running off its own linear regulator and finally an op-amp doing low pass/headphone driving duties, but I'm concerned that the output of a 74xx won't really be suitable.
On the spendy side, I could use a PCM179x part from TI in DSD mode, but I'd need to add a PLL to boost the bit clock by 4x for the PCM's system clock. So board area, and cost, are starting to get out of the question here.
Is there a specific device that I could be using for this? ie., does someone sell a "1 bit in, 1 bit out" DAC that I should be aware of?
Thanks.
Old 6th June 2008, 04:16 PM   #2
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
Why you can't just low-pass it passively and then feed it to an opamp as headphone driver?
Old 6th June 2008, 04:20 PM   #3
ALL TOTALLY WRONG !!!!!!!
In times of high-quality class-d you are obliged to feed the signal into a switching power stage and then filter it passively - of course !!!!!
Charles
Old 6th June 2008, 11:00 PM   #4
hifimaker's Avatar
I'd have to check the datasheet again, but the AD1955 might work without a crazy clocking set-up.
You might consider a voltage out part like the cs4398, just for simplicity of not dealing with an I/V for something like this.
-David
Input transformer: floating input = distortion ErikdeBest Tubes / Valves 13 20th January 2009 09:36 AM
Class D input LM311 Inverting input zox2003 Class D 1 1st February 2008 07:48 AM
current bias j-fet input 2sk170 ,2sj74 at input stage YUTK Solid State 11 2nd June 2005 03:34 AM
convert Quad44 radio input to CD input jives11 Solid State 11 5th March 2005 02:33 PM
Resistor-Input vs. Choke-Input vs. Cap.Multip. Blitz Pass Labs 13 26th September 2003 04:59 AM
Page generated in 0.08179 seconds (70.29% PHP - 29.71% MySQL) with 10 queries
