Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Harmon Kardon HD-970 modded, a world beater?
Old 15th May 2010, 05:44 PM   #121
niewiem is offline niewiem
Originally Posted by georgehifi View Post
Rafal hi, the only simple mod without going beserk like I did would be to change the SMD OP275 I/V opamps for something better, I would suggest SMD AD825's but these are singles and the OP275's are dual so you would have to find a 2 x single smd to single dual smd converter board, this would be the place to look.
Cimarron Technology, Inc.
Single-to-Dual Op-Amp Adapter - SO8 to SO8 version (p/n 031101A)
Cheers George
Thanks, did you heard how so-modified 970 is playing? How it will change sound characteristics of HD970 and is it worth to do this upgrade?
cheers
Rafal
Old 15th May 2010, 09:30 PM   #122
georgehifi is offline georgehifi  Australia
georgehifi's Avatar
Send a message via MSN to georgehifi
From my experience with these two opamps as output opamps the differences are that the OP275 are a bit slow and tubey sounding, where the AD825 has slam and is very fast and detailed yet still sweet, but in the I/V stage ???????
I/V opamps should have good settling times and be quick and the AD825 is better than the OP275 in this regard, as well as having a good sound.
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 16th May 2010, 09:29 AM   #123
1. What changes beside the opamp change can have the greatest impact on sound quality HD970? Can you name/list them ?
2. What do you think about YouTube - Visual Sound: Myth Buster #2: Op Amps ?
cheers
Old 16th May 2010, 12:00 PM   #124
georgehifi's Avatar
ad1955 evaluation board ad1955eb.pdf
Cheers George
Old 16th May 2010, 05:48 PM   #125
Ola is offline Ola  Estonia
For I/V - LM 6172
Old 16th May 2010, 08:06 PM   #126
Chilli6565 is offline Chilli6565  Australia
Talking more mods
Besides the op amps?......well from my experience, I would say put in a good clock ( Burson or LC Audio ) and also replace at least the op-amp supplies with newclassD regulators...they are superb.
good luck
" Digital is only ac anyway "
Old 2nd February 2015, 03:11 PM   #127
CasperG is offline CasperG  Netherlands
Question help needed with HD970
I want to upgrade my HD970 by replacing the OP275's with AD825's. And since I live in Holland where Tentlabs also is based I plan to add a XO2.2 clock with XO power supply too.
Does anyone (George perhaps?) has a schematic how to add these correct in the HD970?
Thanks in advance, Casper
Old 2nd February 2015, 06:35 PM   #128
Question extra info
I just found the oscillator in the schematics and added this as a jpeg.
I think I must remove the oscillator itself and L2, C53 and C55 when I add the Tentabs XO2.2 clock and connect the output to the Pin 5 location on the circuit board (and no other connections to the circuit board are made). The XO2.2 will then be fed by the XO power module. Am I correct?
Thanks, Casper
Old 15th February 2015, 11:20 AM   #129
Use LM67xx series opamps, a lot better.
Harmon Kardon HD-970 modded, a world beater?Hide this!Advertise here!
Harmon Kardon Galaxy BA-150 gfhaban Tubes / Valves 3 2nd May 2016 02:31 AM
Harmon Kardon argonrepublic Solid State 2 23rd June 2009 07:30 AM
harmon kardon T-40 jaudio Analogue Source 0 24th October 2007 11:37 AM
Harmon Kardon T40 jaudio Analogue Source 0 7th May 2005 12:04 PM
Harmon Kardon HK2500 bhg41088 Parts 0 27th May 2004 06:23 PM
