Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 29th May 2008, 07:37 AM   #1
JoeyDD is offline JoeyDD  Canada
Default Extracting sample frequency info from CS8414
Hi ,
I hope someone can help me with some of the questions I have regarding the best way to feed a 6.144 MHz clock to the FCK pin (13) of the CS8414 digital audio receiver.
Basically, what I am trying to do is to get the incoming digital signal's sample frequency using the F0, F1 and F2 pins of the CS8414. F0, F1 and F2 will then be connected to a microcontroller on a separate board. In order to do that, the CS8414's data sheet mentions that a 6.144 MHz clock should be sent to the FCK pin.
I thought of putting an oscillator on the microcontroller board and using that board's power supply for it. I would then connect the oscillator's output to the FCK pin on the DAC board through a wire, and connect the microcontroller board's ground, through another wire, to the DAC board's ground. I am guessing that by doing this I will be injecting some sort of noise from the microcontroller board into my DAC? Is there any way of isolating the microcontroller board from the DAC board and still use the microcontroller board's power supply for the oscillator?
Or perhaps there is another better way of going about this?
Thanks in advance for your help.
Paul
Old 29th May 2008, 09:50 PM   #2
kevinkr's Avatar
You can use BB ISO150 or similar to avoid possible ground loops and and noise injection between your dac board and mpu board.
"Extraordinary claims require extraordinary evidence." - Carl Sagan
extracting enclosure Qb parameter oldbar Multi-Way 2 29th October 2008 06:35 PM
Sample rate converter with fixed output frequency Michele Spinolo Digital Source 1 20th November 2004 04:11 AM
Sample rates Prune Digital Source 9 18th September 2003 07:24 PM
Extracting audio off scanned images of vinyl records! Circlotron Everything Else 10 22nd September 2002 04:29 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
