| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#51 |
I measured other voltages as well, you know, just to see what's there...
For instance required +6.3V for tube heaters measures +5.8V, quite underpowered I'd say. It's a wonder this player IS working (when it actually does). The best thing about it that I'm able to find is its weight - a real brick. Maybe the technical plan (I mean design as it was related in some construction biuro meeting) was good, but the implementation and technical details make me wonder if engineers really new what they were doing. What made them put High Voltage PS and digital transport control on one board next to each other? Tubes and DAC on the same board as well. 1. Power supply. 2. Digital circuits. 3. Analog circuits. |
#52 | ||
Previously: Kuei Yang Wang
Location: Somewhere nice on planet earth where censorship of Ideas is frowned upon
Ciao T |
#53 |
#54 |
There is also latest version of this DAC board based on PCM198 chip. This new version is far better than old, and easier to integrate with tube output stage. I have done several tube output DACs based on this chip and I'm amazed with sound quality wchich is outstanding.
http://www.audiosurgery.beepworld.pl/dacki.htm |
#55 | |
#56 |
Yes, indeed. Sorry for mess.
#57 |
#58 |
From the dig. coax out connector on the back
#59 |
I'm back to the DAC chip Vcc and Vdd supply. As I mentioned before I get +5.01 to leg 6 (OK), and +4.7V to leg 5 (needs to be +3.3V). There are two diodes (zener?) that these voltages are coming from. QUESTION: would changing the value of zener diode help lower +4.8 to +3.3?
I know it's a shitty way to regulate supply voltages for DAC chip, but it's not my design...
#60 | |
I read Lukasz Fikus aka Lampizator website, I like the stuff that he does a lot. He used this board on several of his "Lamipsized" players. The newer PCM1798 version uses 3 OpAmp chips instead of only 1 in the original. I will try to repair the original DAC chip circuitry on my player and also install the Lampucera board for comparison. I already changed tube stage to single tube cathode follower - much better solution. |
| List of Mod-able CD Players | DreadPirate | Digital Source | 2 | 26th February 2012 06:22 PM |
| Quality of Mp3 Players ! | -_nando-_ | Everything Else | 21 | 1st May 2006 05:42 PM |
| CD Players | deanbo | Digital Source | 3 | 25th July 2005 05:57 AM |
| CD & DVD players f.s. | Cobra2 | Swap Meet | 6 | 16th March 2004 07:26 AM |
