| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
The attached image shows the 2,82 MHz clock at the BCK input of my NOS TDA1541 DAC. Time base is set to 100 nS/div.
One more image to follow... Paul |
#2 |
This second image shows the same clock signal but with the "persistent trace" option active. Time base is again set to 100 nS/div.
Question: Since the signal time drift stays within less than one third of a division, can I conclude that the clock signal has a jitter of about 30 nS peak-to-peak? Best regards. Pau |
#3 |
What you see on the screen of a scope is the jitter of the signal PLUS the jitter of the timebase. The latter may be much bigger than the signal being observed. Try NORM trigger (not AUTO), set the timebase so that you can see only one signal transition in the middle of the screen (the first transition is at the leftmost where the triggering takes place), set X10 horizontal deflection and find the signal transition with HORIZONTAL POSITION. Then you minimized the effect of the timebase and you can use it for quantitative comparison.
| generate jitter test signal and measurign jitter using AP2? | BJAMR | Digital Source | 11 | 1st November 2010 02:07 PM |
| Measuring jitter | oshifis | Digital Source | 2 | 8th September 2010 08:35 PM |
| Measuring word clock jitter with Audio Precision System 2 possible? | deskmate88 | Digital Source | 0 | 24th December 2004 03:39 PM |
| Data Jitter Versus Electrical Jitter? | 300_baud | Digital Source | 8 | 16th July 2004 07:59 PM |
| Measuring Jitter | jackinnj | Solid State | 3 | 7th March 2003 09:17 PM |
| Page generated in 0.06934 seconds (69.15% PHP - 30.85% MySQL) with 11 queries |
