| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#21 |
I'd have to disagree with you on the 'way more difficult' bit.
While it can take a few chips if one insists on using TTL/CMOS logic, a CPLD or FPGA provides a flexible one chip solution. ray. |
#22 | |
I1 = Isig + Inoise1 and the second DAC output is I2 = Isig + Inoise2 where all values are RMS. When uncorrelated noise sources add, the resulting noise is sqrt(Inoise1^2 + Inoise2^2) If Inoise1 and Inoise2 have the same RMS value, then the total noise is 1.414*Inoise so Itotal = 2*Isig + 1.414*Inoise Therefore, although the noise increased by a factor of 1.414, the signal increased by 2 so the SNR improved by a factor of 1.414.
Mike "Never confuse motion with action." B. Franklin |
#23 |
Mike, that's exactly what I was saying. Noise adds but coherent signal adds more so the s/n increases, anyway in the interim I think I got your earlier post, although staggering would require a much more complicated circuitry than simple parallel.
What does quantization noise look like? Excuse my ignorance, but what happens if you send a signal to one dac, a signal 180 deg out of phase to another dac take the outputs from the two dacs and subtract them? Wouldn't that get rid of the quantization noise? |
#24 |
"Quantization noise" is more accurately called "quantization error". Quantization error is actually introduced during the A/D conversion process - it is the difference between the quantized (digital) waveform and the analog input waveform. An ideal A/D converter basically "rounds" the analog input waveform to a finite set of discrete quantization levels - imagine rounding a real number (infinite precision) to an integer (finite precision).
If certain assumptions are made (mainly that the input signal is constantly changing and is not synchronous to the sampling rate) then the quantization error can be viewed as a uniformly distributed random number which can range from -0.5 LSB to +0.5 LSB (where LSB is the size of one quantization level of the ADC). Quantization error from sample to sample is uncorrelated (i.e., the quantization error at sample N is independent of the quantization error of all previous samples). Given these assumptions, the quantization noise looks like white noise with RMS level of LSB/sqrt(12). Since quantization noise is introduced in the A/D conversion process, by the time it gets to the DAC it is actually part of the signal. Nothing can be done at the DAC end to eliminate it - at least not without affecting the signal as well.
#25 |
I decided to test "piggyback" two pairs of PCM1704K. I could only compare between a single and 2 in parallel (I'll do balanced later)
I believe my set-up is reasonably neutral and transparent. I out from the DAC chip goes directly (20 cm of double shielded cable) to the +input stage transistors (2SC3722 and 2SA1455K) of the power amp (LC Audio Millenium run on batteries with 0.5F elyts and added MCap PP decoupling at every appropriate transistor (50uF on the legs of the power trans)). The volume is controlled by low value resistors to ground and the -Input on the power amp, test volume load (DAC load) between 100 to 500 ohms. The speakers are Dynaudio Contour modified using metallfilm resistors, CFAC coils and MIT MultiCap RTX. I realize I have a somewhat different set up for the IV conversion and that this might play a role in my findings... However in this set-up parallel dacs sound MUCH worse, upper midrange and high range completely looses transparency and precision and gets gritty and harsh. Really not much more to say, it really sounds bad. The only thing that may have improved was upper bass or perhaps that was the only area my ears could stand, the level obviously increases. There is no way I am going parallel. I am pretty confused why others find it better |
#26 |
Forgot another piece of info that might explain my findings...as you probably figured there are no analog filtering except what is done by the poweramp and speakers, the power amp has a -3dB of 500kHz.
Prior to the dacs the signal is upsampled to 24/96 and then oversampled to 768kHz. I run the dacs directly on a 24.576kHz clock. |
#27 | |
#28 |
DIY !
Did you try "the Monarchy Audio" way?
(they used only output from the "piggyback" chip) Attached: PCM63-K) Arne K |
#29 |
"paralleled" DACs, as stated by Mike, can enhance s/n) by
3dB for every doubling of the number of converters. (this concept is very appealing to Burr-Brown/TI and Analog Devices...) However, unlike what some have said (including an audio converter guy, Bob whats-his-name at ADI), distortion is NOT reduced, in general. To reduce distortions would require that the nonlinearity errors in the various bits be random. In practice, any bunch of converters you buy for this sort of project will likely be from the same lot and thus be very likely to all have their errors skewed in the same direction. Thus they'll be highly correlated. On the other hand, buying the premium grade of any DAC is a very good guarantee of getting better linearity and hence lower distortion. One common practice that seems guaranteed to mess up the DAC's linearity is to use a resistor on the output of a current-out DAC for the I/V conversion rather than an op-amp summing junction. Saw some curves that a friend did recently and the resistor version was pretty pathetic.
bel |
#30 |
-Yes I am using passive conversion.
Right or wrong I found it to be sonically prefered. Before settling for the passive variant I used the opa627 as I/V converter and my perception was that I actually had lower overall distorsion with the 627. I lost on more subtle things like "body" and 3-D feel, "drive" Particulary the interchannel time precison (not measured, just perception) was significantly better using passive conversion which convinced me to go passive as it really pulls you into whatever you listen to. Michael |
| Parallel with different chips! | Matthewong | Chip Amps | 18 | 2nd September 2011 03:17 PM |
| gainclone chips in Parallel | steven344 | Chip Amps | 2 | 21st November 2005 05:52 PM |
| Elegant way to feed parallel data-input DAC chips ? | Bernhard | Digital Source | 27 | 18th April 2005 10:28 PM |
| Active Feedback on Parallel Chips | Stocker | Chip Amps | 8 | 4th May 2004 10:40 PM |
| can I parallel 7812 Chips | PaulHilgeman | Parts | 16 | 6th May 2003 10:05 PM |
| Page generated in 0.13077 seconds (83.29% PHP - 16.71% MySQL) with 11 queries |
