| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hi All,
I am in the early phases of designing an active / digital bookshelf system. I am planning on using a squeezbox as a source. I'd like to run the SPDIF output from the squeezebox into a digital crossover / processor. I've investigated a few options here: Behringer DCX2496 (modded) Rane RPM 26z Ashly Protea 3.24CL Is there any problem going from the SPDIF output of the squeezebox to the AES/XLR input on these? Any good recommendations on cables? Also, it seems like volume control is an issue. I know Selectronic has a 6 channel volume control that could work here. Are there any units where the volume control is integrated? How about the Ashly? I haven't put too much thought into the amps as there are a lot of pro or home audio options there. As far as drivers, I was thinking about going with a Raal ribbon tweeter and a Scanspeak Revelator mid/woofer. Any thoughts or opinions especially regarding the crossover / processor are greatly appreciated. Many thank in advance Jim |
#2 |
I use a Roku SB500 feeding a Behringer DCX2496 for a 3-way active system. Any RCA-XLR adapter should work, I made my own cable.
I know it's heresy, but the Roku has a volume control that affects the SP/DIF output, so I just control volume that way. I use Trends TA-10s for high and mids and a Gainclone for bass. Speakers are Hawthorne Audio Silver Iris Coaxials and Augies. All in all, it's a nice little system. Surprisingly inexpensive and simple for a 3-way active. |
#3 |
Thanks vm. Will I have any sound degradation by doing the volume control from the squeezebox?
Also, I want to make sure I understand the signal path correctly. I'll be sending an unbalanced digital signal from the SPDIF output of the squeezbox to the AES/XLR of the digital crossover / processor. Then I'll be sending a balanced analog signal from the XLR output on the processor to the XLR inputs on the respective amps (assuming I get amps with balanced inputs). Is my understanding correct? I've been leaning towards the Ashly. It looks like a nice piece of equipment. Does anyone have any experience with it? |
#4 |
bump. help pls
#5 | |
Of course, other methods also cause degradation of sound quality. And there's nothing stopping you from adding a 6-channel, ganged volume control at a later time. Your understanding of the signal path is correct. You can use amps with balanced inputs, or convert the signals back to unbalanced. |
#6 |
I can't seem to find any 6 channel volume controls with balanced inputs and outputs. Anyone know of one?
#7 | |
#8 | |
#9 |
Here is a project for a six ch volume control for DCX2496:
http://www.linearaudio.nl/6chan-1.htm Another source is : http://electronics.dantimax.dk/ RELVOL3 is a stereo balanced attenuator and you can put three in a CONTROL2 board. Hope it helps
#10 |
You could easily do a variant of the Lightspeed Attenuator.
Lightspeed Attenuator a new passive preamp Modify the circuit for balanced operation (I'm not sure exactly how you do series-shunt attenuation on a balanced circuit, but I'm sure someone does). Then use one pot to control all 6 channels. Should be one of the cheaper options available and very good sound quality. |
| My New Active 3-Way System | wigginjs | Multi-Way | 15 | 26th October 2009 08:06 PM |
| active system, first pictures | aaronboumans | Pass Labs | 39 | 11th July 2005 10:40 AM |
| Zobel for Active system | BlairHatcher | Chip Amps | 9 | 30th October 2004 08:11 AM |
| possible active system | bonsai171 | Solid State | 5 | 13th July 2004 03:41 AM |
| Three-Way Active System with 15" | RussianBlue | Multi-Way | 10 | 9th March 2004 01:47 PM |
| Page generated in 0.10162 seconds (87.88% PHP - 12.12% MySQL) with 10 queries |
