Problem with SPDIF comparator (Elso) - Page 5 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 13th March 2003, 08:14 PM   #41
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Hi Elso,
Thanks for the response. I won't further pollute this thread, but start another one in a week or 2. I don't agree with Joco
Old 13th March 2003, 08:57 PM   #42
Banned
Send a message via Yahoo to Elso Kwak
Talking SPDIF
Hi John,
I don't consider your post tread "pollution"
I have thought about using balanced signal from the player transporting it by two coax cables driving both inputs of the comparator. But after all I totally stopped working with the interface as I am now using the "one box solution".
Old 15th March 2003, 07:22 PM   #43
jwb is offline jwb  United States
jwb's Avatar
Send a message via AIM to jwb
On the subject of pulse transformers and how to obtain them, I've been happy with Scientific Conversions. They are located in Petaluma, CA which is local to me, and they will ship small quantities, although I've never ordered fewer than five. Their prices are also quite low, and they have both surface mount and through-hole, although the surface mounts are better.
Old 15th March 2003, 08:30 PM   #44
diyAudio Retiree
Default Aes Ebu
"Doesn't anyone use balanced AES /EBU format with XLR's (at 5v P-P)?"
I have designed with this interface also. The potential for reflections is even greater than with an SPDIF with RCA connectors. XLR connectors are an incredable mismatch at RF frequencies and ever more difficult to design impedance nulling circuits for. They have a longer propagation delay and look more inductive. There is even more variation of these parameters for connectors from different manufactures than for RCA connectors.
Pulse transformer design become even more difficult since the higher impedance requires a larger primary inductance. This requires more turns for a given core type which leads to increased leakage inductance and reduction in bandwidth. The signal level also make saturation and distortion more of an issue.
Balanced cables consist of a twisted pair inside of a coax shield. Optimal ternination requires consideration of both the differential characteristic impepedance of the twisted wire pair and the common mode inpedance of the twisted pair in relation to the shield.
The much higher drive level also has the potential for more common mode noise to get from the transport to the DACs analog circuits. The higher drive levels do allow for more attenuation though. My premium AES cable use two 75 ohm coax
(one for each phase). Impedance matching was achieved with a resistor pad. The attenuation from this pad also helped to minimize signal reflections from the XLR connectors. These cables used extensive mechanical damping and a 40 volt bias voltage between the AC coupled shields and the center conductor. The only real advantage to the AES EBU balanced digital interface was that the Crystal input receiver was drive diffentially and at higher levels than the usual SPDIF implemetation. The interface circuit described above achieves the same benefit for driving the Crystal differentially and with much less tradeoffs the the usual AES/EBU balanced digital cable interface. I hated building the balanced cables and a suprising number of people paid $650 dollars retail for them.I think this cable is the hardest cable of any cables to get to sound good. It took over a year and a half for me to become satisfied with the design. It sounded very good but required way too much effort to get to where I was happy with the design.
"On the subject of pulse transformers and how to obtain them, I've been happy with Scientific Conversions"
I have evaluted them and found them to have the same design trade offs and simular measurents the Schott units and were considerably more expensive.
Old 27th March 2003, 01:30 PM   #45
Banned
Default How did I miss this one???
Elso:
I never told you it would not work, or not to do it. I just gave you some hints to make it work better. And it did, as I recall.
I saw no reason to upset your apple cart just because you chose a scheme other than what I would do.
OTOH, Tyler did ask me for my specific recommendations. So he received them.
dhaen:
What exactly is it that you don't agree with me on? I'm sure the gang would like to know. Start a new thread, if you prefer.
Jocko
Old 25th May 2003, 09:43 PM   #46
Oli is offline Oli  United Kingdom
Question Needed: Schematic of Input Stage for CS8412
I am also interested in an improved input stage for the CS8412.
Does anyone have an operating schematic they would like to share?
I like the idea of the 74HCU04 with 74HC86 wired as a phase inverter, but how is this all achieved in practice? No site or thread seems to have the detail required to build this particular input stage.
Oli
Old 26th May 2003, 12:03 AM   #47
See the second page of this thread.
Old 26th May 2003, 07:45 PM   #48
Question Any improvements to CS8412 Input stage?
Thanks rfbrw!
I gather you are referring to the diagram posted by Elso Kwak at the beginning of page two.
Modifications mentioned elsewhere in the thread include:
1) Delete C2 and C3.
2) Connect a 2k resistor at the node between U1:A and U1:B and bring this to ground.
Are these valid and do they sound better?
If I connect a pulse transformer across R3, leaving the input floating, is this okay? If not, where else should I tie the input of the transformer?
Oli
Old 26th May 2003, 11:25 PM   #49
jean-paul's Avatar
Reread this thread. Please use the Search function for information on questions. You were probably not the first that asked that particular question before
The new Nonoz II DAC page !!!
It's only audio. Member of the non modular PCB design committee
Old 26th May 2003, 11:40 PM   #50
The circuit is meant to replace the transformer. I cannot really comment on how it sounds as at the moment there is a lot junk after the CS8412 on the two boards that have the circuit but it does work with all the various sources I connect to it unlike my Mission DAC5.
When I built the circuit I did leave out the two caps at
RXN and RXP along with the 2K resistor and have had no problems.
CS8414 spdif problem pigoia Digital Source 33 9th March 2008 06:21 PM
Problem with Elso clock falter Digital Source 19 19th November 2006 02:53 PM
Issue with SPDIF Input Circuit by Elso and Jocko 300_baud Digital Source 18 8th April 2005 06:56 AM
Elso Clock in CDT or DAC patricklyw Digital Source 28 15th December 2003 10:25 PM
Copyright 1999-2017 diyAudio
