Weird hats aside, some of us have done a lot of research into this. We strongly feel that using isolation transformers function better that direct connections. We have also done a lot of research into what transformers work, and why.
And the bottom line is to use a transformer, and one with as little leakage inductance as possible.
And yes, all the loop filter mods and other tricks are still a bandaid for a poorly conceived interface.
Jocko
Found this quote from Jocko when I did a search for pulse transformer because I remembered this was discussed before. As often Jocko hits the nail on the head. And the simplicity of a good transformer has more sex-appeal to me than a bunch of digital IC's that all have their drawbacks. This does not mean I hate IC's or whatever. Sometimes simple solutions are the most effective. This is such a case. Please consider this is only true in case one uses a real good pulse transformer. Otherwise, don't bother.
I rolled my own before but it just takes too much time and has to be done real, real good. This was the Elektor type as used in their Mini DAC with the PCM1710U.
Then I tried Lundahl LL1566 which is an improvement but it is not perfect. The Lundahl has the advantage that it is easily obtainable. Despite it's technical drawbacks it is a good solution compared to electronics. So I can recommend it even though I know there are better types around. For some strange reason I did like the Lundahl more when used at both sides. In the cdplayer and in the DAC.
I could have lived with the Lundahl but then I saw another type/brand at a suppliers. That one is still in test phase so I won't go in detail for now.
I concur with Elso about the dismissal of SPDIF altogether. If one wants the best; build a DAC and output stage IN the cd-player in a shielded box. Make sure you build separate power supplies ( separated from the cd-players supply that is ) with their own power transformers. It will be better than with SPDIF even when one uses the non-plus-ultra of available transformers.
Jean-Paul
Hi Wombat,
Please read this thread for information on this subject:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=3282&highlight=pulse
I think Harry fell over laughing the last time someone mentioned LL1566. And Jocko seems to hate those AudioNote ones that some commerical designers seem to think are the best thing since sliced bread.
Honestly, the real hi-end guys are going to be critical of almost everything, since they took the time to find the best components.
If you recall, Jocko hinted that the Schott trannies that Digikey sells aren't a bad place to start.
A transformer isn't all you need in many cases; quite a number of DIR require CMOS level. If you use a 1:2 Scientific Conversions tranny you can get away with no additional circuitry, but I'm not certain you should. A buffer goes a long way towards cleaning up the crud.
Fine with me but even LL1566 is better than direct coupling. I did try, I even have a DAC with the part still in it. I don't know the ( in) famous Audio Note part but if I look at the pictures of it I have my doubts about it's electrical capabilities. The winding techniques used seem not the best for a pulse transformer. But as always : it is not fair to judge a book by it's cover. I don't know it and haven't heard it as far as I know. Or it should be DAC 3 that has it ?
What "real" high end guys want I don't know. Some of them criticise everything and quite a few of them only listen to the faults of devices. Being mystical about foggy technical solutions, brand-awareness and the criticism to unknown devices or parts make that the qualification "high end guy" may be good for others but not for me. In the end the high end market is like anything else: it's about money and status. BTW I am just servicing a expensive brand DAC that has a pulse transformer in it with a bandwidth of only 1 MHz !!
The Schott parts seems to be good but I was never able to find one myself. All I know is that the company has a reputation for producing quality pulse transformers.
In this case it is about what is possible to use instead of the electronic solution.
A transformer is useful for galvanic isolation if you don't need it for differences in level. The Lundahl is a 1:1 transformer. No garbage creeps in to your DAC via ground if you use one. Please see the datasheet of CS8412 what it accepts at the input. ( Not the best advice since the readablity of this datasheet ! ).
The Crystal part couples some garbage back to the input. That effect is less if a transformer is used.
jean-paul,
I was less concerned about garbage from the ground than general degradation of the waveform. A really good source will deliver a clean signal, but if you have reflections and other problems due to insufficient cable or pulse transformer bandwidth it really helps to have a buffer to clean things up.
Ok, Tiroth. But reflections are a reasonably controlable problem. It takes real 75 Ohm cable for a start, not microphone-cable as I saw a bit too often.
So let's assume a clean signal from the source and a well designed output stage of the cd-player. We have real 75 Ohm cable with the right bandwidth ( BTW which 75 Ohm cable hasn't the required bandwidth for SPDIF ? ). We have to start somewhere don't we ? Ok ?
That leaves us the problem of a decent input transformer, right ?
Please explain the need for a buffer instead of a transformer as I really don't see the need for it when all other variables are designed according the rules. Hereby I refer to the schematic as given in this thread. And if the other variables are not according certain rules solving that problems first is a pre in my book.
Everything you wanted to know about the SPDIF*
* but were afraid to ask.
The input circuit show is not my creation but that of Scott Nixon who builds some of my favorite DACs (I have two of his DAC boards)
In previous life I designed digital interface devices and digital cables for the Audient Technologies products. I am a serious advocate of pulse transformers and they belong at the transport end of the interface where reflections due the impedance mismatch are absorbed before the round trip delay from the cable propagation time complicates things.
The design of a pulse transformer for this interface is a very complicated thing. a good pulse transformer shoud be flat from about 50KHz to 30MHz. 1 to 1 turns ratios are best since you can do bifilar winds and get more precise impedance matching and lowest leakage inductance. I was fortunate to be tutored tutored in this art by John Marshall who designed transformers for Schott and was an extremely knowledgeable designer. Almost all pulse transformers are designed for the lowest capacitance between winding (and hence the lowest common mode noise coupling possible.) This leads to some serious compromises in impedance matching at frequencies above a few MHz. This impedance mismatch is caused by the permeability changes and resistive losses in the core material as frequency increases. Also Reflections at lower frequencies are due to the primary inductance of the transformer.
I designed a product called the Tactic which was an external module containing a hand wound pulse transformer of my own design. I traded off an increase in capacitance for improvements in distortion and impedance flatness to several 10s of MHz. The Tactic also contained zoble networks for neutralization of leakage inductance, a few dB of intentional resistive loss (a pad often used RF interfaces) , and battery biased ERO polypropylene coupling caps. Oh yeah... it retailed for $350.
For the DAC end product was a module called the Audit that contained an analog devices monolythic differential video amp to buffer the digital cable from hysteresis and impedance mismatch from the DAC digital input. The digital interface is about as sensitive to component quality and cable microphonics as the line level analog interface and development of these products took over two years of computer modeling, listening test by several people, and TDR measurements. This is not simple interface and is the bottleneck for most Transport and DAC combinations. RCA connectors work very well for digital interface with a simple two element network soldered in the male connectors for better impedance matching. They sound better than many BNC connections that I have listened to. You can hear the difference in caps in this interface and small polypropylens of 100 volt ratings or less sounded best
all though I did hear a 100 volt RelCap Hematically seakel 0.1uF teflon that sounded very good but was about $45. A 1uF Black gate also sounded very good.
http://www.google.com/search?q="Audient+Technologies+"&hl=en&lr=&ie=UTF-8&oe=UTF-8&filter=0
RCA
The pretty shot path of a RCA connector can be aproximated by a capacitance. An L R network can be matched to pretty much null this impedance. I sold the design to a cable manufaturer so I don't want to be more specific than that. I used Cardas RCAs and I hear Keith Eichmann's Bullet Plug works even better for the male RCA but is difficult to terminate the shield the the connector ground.
Input Circuit with 74HC86
Hi Fred,
Scott Nixon informed me:
"You don't need the caps in front of the inputs of the receiver, and the 2k should see the node between the hex sections and ground."
I don't understand this as I did my very best to translate the words of your old post into a schematic Philw asked for. Please advice.
Rather than using a resistor/cap network in the RCA connector I prefer using 75 Ohm BNC, Lemo or F-connectors at both ends of the cable.
Your explanation of the manufacture of the transformer is interesting but hard for the average DIYer to build or clone. Leaving us at square one: how to get the most out of the interface? Or asking the question what is the best ready built transformer for use at the transport end? For me the vagueries of the transfomer are a reason to omit it alltogether. I did hear a improvement when I omitted the original transformer in the Philips and Sony player. But of course these trannies aren't up to your standard....
Elso/not into SPDIF anymore
/not into transformers
Hi Fred,
I think Mr. Nixon advocates the use of another 2K resistor to act as a pull down to ground for the first hex inverter section. Might be worth trying but I have not used it.
The use of an UNBUFFER 74HC04 is required to make the first hex inverter into an amplifier. The 2K and 47K ohm resistors make the first Hex inverter look like an inverting amp with a gain of about 23.5. This allows 0.5 volts to overdrive the hex inverter/amp to acheive full logic transiston. The analog input signal is being conveted to a logic level digital signal by this stage The next hex inverter speeds up this logic transistion rise and fall times and buffers the first hex inverter/amplifier stage to drive the other logic. No capacitors are required at the schmitt trigger type inputs on the Crystal semiconductor inputs since they are now being driven at logic level inputs that swing between 0 and 5 volts. Do not use an inverter to drive the other reciever input as the unequal propagation delay to the receiver inputs due to the extra inverter to the screws up the sound. This circuit works quite well and was proof to me that Mr. Nixon is a talented designer. ( that and an amazing amout of excellent advice on audio design he has given me over the years! )
You would not believe the input circuits I have seen on some very famous and expensive DACs. I once very noticably iimproved the sound of a 5000 dollar DAC by removing half a dozen parts from the digital input circuit. Oh it had a nice 75 ohm BNC connector on the input, but input circuit didn 't even look close to a 75 ohms resistive input Jocko and I laugh are butts off when we see DACs with 50 ohm BNC connectors wired to input receivers with 4 inches of 110 ohm twisted pair wire. Impedance matched input? I don't think so! I have measured everything from 35 to 150 ohms on a "75 ohm" digital input. That and inductors, capacitors, relays, switches, and wire or printed circut board traces that were not 75 ohms; allowed me to sell quite few of my external input buffers to the owners of some very expensive DACs.
"resistor/cap network in the RCA connector" That might be because it is an inductor and resistor required for an RCA plug, Elso.......
The problem with BNC connectors is that some are made of pretty nasty materials compared to a good Cardas RCA connector. That and a typical RCA BNC adaptor that gets used when mixing RCA and BNC connectored equipment are the kiss of death for a digital interface. They sound really bad and I sold over a hundred custom adaptors made from Cardas and Canare connectors to lots of happy customers. Digital cable with an RCA on one end and BNC on the other cannot be reversed. Digital cables are often very audible for direction as the cable does not maintain the same caractistic impedance down its length and the termination impedance at the connector varies somwhat.
Slightly off topic, so please indulge me for a moment:
Why is there such an obsession with SPDIF?
I know it's the domestic common format, but this is DIY, we can do as we want
Doesn't anyone use balanced AES /EBU format with XLR's (at 5v P-P)?
This is a super format that goes for enormous distances with minimal deterioration. You can directly couple into the Crystal receivers, so there are a minimum of stages.
I use pulse transformers at each end, and standard 110 ohm balanced cable. The voltage waveform looks imperfect because of the pulse transfomers' reactance, but the current waveform looks just fine.
I have an adjective deficiency for describing sound, so I respectfully suggest you try it yourselves.
Thank you for your time..
driving cs8412 differentially ... again
quote from Fred
>quite well and was proof to me that ...
I'm still trying to get my head round this. Please could someone help me on this ...
Is Fred referring to the schematic earlier in this thread and saying that the second gate of the 74HC86 should NOT be used to drive the CS8412 differentially because it produces a bad effect by introducing unequal propagation delays?
Or is he saying DO use a 74HC86, because the alternative of doing it via an inverter produces the bad effect.
quote from Fred
Re: driving cs8412 differentially ... again
Hi Philw,
I believe the second circuit I posted is the correct one as Fred meant. The trick with the 74HC86 is the inverted and non-inverted signal pass the same number of stages which is not the case if you use a extra inverter to obtain the inverted signal.
It was used in the Pass DAC D1 schematic to obtain inverted and non-inverted DATA!
John,
The schematic I made with the OPA603 and the AD8561 comparator is totally off AES/EBUnorm. It produces a 2.5V signal at the input of the comparator. I feel coax cable is better suitable and defined than 110 Ohm twisted cable. Jocko told me the latter is hopeless or words of the same meaning.
PhilW said:quote from Fred
Hi Philw,
John,
- Digital Source
- Problem with SPDIF comparator (Elso)
