Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 22nd April 2008, 04:04 PM   #1
Default Coax input deq2496
Have anyone add coax input to the deq2496.
I think it would be possible to tap into the ak4114 RX0/RX1 input for the coax in. Refer to page 22 on ak4114 datasheet for the optical receiver input (with 470R) which is same as the optical circuit in deq2496.
It looks it I can solder a coax wire on input side of the 470R resistor (connected to the RX1 pin of ak4114) and put a 75R across the coax wire and put a BNC at the wire end and I am done.
Anybody done this yet?
...chuck
Old 22nd April 2008, 04:11 PM   #2
Refer to the pic, that would be R8 (470ohm) which is tie to RX1 (pin 44) and goes through pin 32 in the cable to the optical input.
R9 would be the digital balance input and has a 0.1uf cap connect to the RX0 (pin 42).
Old 23rd April 2008, 02:00 AM   #3
rossl is offline rossl  United States
rossl's Avatar
Are you using the XLR input?
It may be easier to convert the XLR into a coax input. It is transformer coupled. Your plan would not be.
Build a special cable with coax on one end and XLR on the other, then change the 110R terminator resistor to 75R.
Old 23rd April 2008, 03:45 AM   #4
I will bypass the XLR and the 110ohm tranny of cause.
Converting 110R to 75R won't be very good for jitter, I believe.
I want a clean path if possible.
I see 2 digital input,
1. XLR->tranny-> 470R-> 0.1uf->AK4114 RX0, or
2. Optical in-> 470R -> AK4114 RX1
It would be great if someone confirm this and can be replaced by
BNC-> (75ohm across) -> digital tranny -> 0.1uf-> AK4114 RX0 or RX1
TIA.
Old 23rd April 2008, 05:51 PM   #5
It works. It is very simple. I solder a coax cable with signal to C15 and ground is C16, add a 75ohm and bnc or rca and I am done.
I believe the R9 (470ohm) will need to be remove too for correct 75ohm.
My 2nd deq2496 is making sound now using coax input (I kill the 1st one a while back).
Next mod, bypass the opamp for direct out!
Old 28th April 2008, 03:45 PM   #6
Here's a pic of the spdif direct mod.
Old 28th April 2008, 03:48 PM   #7
The 470ohm is removed.
I would say this is a really worth while mod for those that uses spdif.
The aux out is removed for the bnc connector. A C&D DA101 tranny added.
DEQ2496, then input info into a DCX2496? mazeroth Digital Line Level 1 21st September 2005 05:25 AM
AES/EBU to SPDIF coax input, how? tubenut Digital Source 48 16th February 2005 07:45 AM
Is there a DIY coax input for M-Audio Revo 7,1? Ryssen Digital Source 0 1st June 2004 10:43 PM
Changing toslink to coax input whompinjack Digital Source 1 9th April 2004 06:24 PM
Coax. input problem androll Digital Source 0 29th January 2004 01:42 AM
Page generated in 0.08522 seconds (75.90% PHP - 24.10% MySQL) with 11 queries
