| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I thought I'd open mine up. I was hoping to bypass the DC blocking caps on the DAC so I can try some better caps by putting them in the cable.
You can search and find what it does and what it looks like so I won't go over it all again here. The board is riddled with 22uF surface mount electrolytics (18 of them). There are a few 220uF for power supply filtering. I'm not a fan of surface mount electros, they often leak after a few years. ADC is an AKM 5537 DAC is an AKM 4385 Summary of the specs of the DAC: 108dB 24 bit 192kHz (only used up to 24/96 in this appication) 128x oversampling. differential outputs which do not require DC blocking caps. After the DAC is a JRC NJM2100 dual op-amp, half is used for each channel. I found a datasheet and it doesn't look particularly special, they say: "It is applicable to Handy type CD, radio cassette CD and portable DAT audio apparatus which require the 5V single supply and high output voltage." After that things start becoming a bit hazy, the traces are hard to follow with the high density components and white silk screening. It is only a 2 layer board so it would be possible to trace the circuit out if you were sufficiently motivated. There are no less than 7 of these NJM 2100 op-amps all over the board. But the UA-1EX has heaps of analog and digital inputs and outputs so I assume they are mainly buffers. The board is of a reasonable thickness. soldering looks quite good on the larger pads so the sockets shouldn't fracture, but it is lead-free solder which we all know is sheer madness but a political necessity. After learning this I'm not going to bother modifying my UA-1ex, but chances are someone else will consider doing the same thing I was thinking of doing. So I thought I'd share what I found out. The device as it is sounds pretty good to me. I've been making a lot of changes elsewhere in my system and I've not listened to very many DACs so I'm not a reliable reviewer.
Help some guys with funny hair bang two rocks together really hard. http://athome.web.cern.ch/athome/LHCathome/whatis.html |
#2 |
Did you identify the USB reciver chip? I´m searching for a 24/96 capable chip that can output i2s or s/pdif.
#3 |
My recollection is the Edirol UA-1EX is 24/96 USB compatible. Larry Lavry recommended this product for USB to spdif for his DAC's.
-David |
#4 | |
#5 |
Thanks! From the interfaces supported by the AKM 4385 I would guess they use the i2s that I can tap into.
Big problem with jitter though from the TAS1020B. Especially if it runs in syncronus mode. I plan on using the ESS Sabre as DAC which is supposed to have great jitterreduction. Guess Ill find out.
| PC sound card sound chips | kaluchka | Chip Amps | 6 | 20th June 2011 03:48 PM |
| Which sound card? | MMeche | Digital Source | 1 | 28th June 2008 11:17 PM |
| What Sound Card for PC T&M | primalsea | Multi-Way | 3 | 8th February 2006 02:08 AM |
| Can your sound card do this? | jackinnj | Everything Else | 25 | 7th November 2005 11:32 PM |
| USB Sound Card | GianLorenzo | Parts | 3 | 16th February 2005 06:33 AM |
| Page generated in 0.08922 seconds (74.29% PHP - 25.71% MySQL) with 10 queries |
