Finally, an affordable CD Transport: the Shigaclone story
jims said:
Audio1st,
Beautiful job. I want one just like it. How does it sound? What changes di you make to the board.
JimS
Hi, It sounds the most natural to me so far.
I ended up with a single 8V supply because it sounded better to me.
Also kept the original oscillator and C906, but changed all the other mentioned caps with low cost Rubycon's of similar values.
I expect my "Monarchy Audio delux 18b" DAC may be the weak link now?
Yes we took the trouble of taking a motor carefully apart and getting rid of the coils etc...and use it in its empty housing...
We mounted it (you have to buy 2 boomboxes...1 small tiny white wheel per machine ...hahahahaha) with a second motor this time one powered and with a little tension on the belt.....and GO
Obviously it was an experiment and although it worked it had loads of jitter....(a lot of difficulties to overcome....first spindle/platform/belt/second spindle ..it all has to be perfectly straight but it is NOT....etc etc)
I will not go as far as making a better spindle (couple of mm thicker) with ball bearings and oil etc etc....We reckon it most certainly will work but the mounting as I have planned will suffice more than enough for me...
I probably have still some photo's of this experiment at home..I will search...
audio1st said:
Hi Erik, have you tried tuning the PS.?Here
I know you like to experiment and you also have the ears for it:worship:
I'm sure it has made a difference to mine..
No I have not although I do use the wimas in other positions..
Today I took some time to built the mock-up to get a good feel for sizing and design...
This way I know later on how to exactly use the expensive ebony/copper/acryl....etc.
The powersupply is imitated by the crosswood between the frontlegs..
The height is approx. 75 cm.
Joined 2003
Metal Source
Peter Daniel said:
The bars have been cut on table saw and smoothed out on belt sander, they are connected with 10-32 screws (two per each corner). The size is approx 7 x 7.5 x 1.25" There is 3/16 copper plate attached on a bottom and it holds the mechanism:
<SNIP>
Ok, I am over my summer model aircraft frenzy and ready to build my Shigaclone. I want to do a Peter Daniels-style bronze/copper frame and am looking at metal sources. So far I'm looking at OnlineMetals.com. Any other sources worth seeing before I place an order?
Also, for another project, anyone know of a good online source for Corian sheets?
TIA!
Greg in Mississippi
