Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Finally, an affordable CD Transport: the Shigaclone story
Old 9th May 2008, 05:14 PM   #881
luvdunhill is offline luvdunhill  United States
luvdunhill's Avatar
Peter: I like the ML31.5 approach the best. A few questions:
1.) how tall are the springs with no load
2.) what is the outside diameter of the spring
3.) how tall are the springs with the load
4.) how much does the load weight?
5.) what is the shape of the wire: square, oval, round?
I think we can find these easily. Also, the socket caps should be easy to find as well.
I will calculate the resonant frequency of the above and then scale it to how much my metal frame will weigh and choose the spring based on this.
Old 9th May 2008, 06:46 PM   #882
kevinkr's Avatar
Good approach, but don't assume that this will get you all the way, I would recommend getting springs having characteristics that bracket the calculated value by a wide margin. What ends up working best may not be what you initially calculated. (For example how do you choose the optimum resonant frequency for the mechanism mass given other variables like what you have it placed on? And its resonances..)
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 9th May 2008, 07:00 PM   #883
MrMajestic is offline MrMajestic  Sweden
MrMajestic's Avatar
Originally posted by MrMajestic
I have one spare EZ31 that I could part with if someone is interested. Realized I went a bit shop-happy when I found out they were in stock here
The player is no longer available. Its on its way to Norway for maming and mutilation
Old 9th May 2008, 08:28 PM   #884
superhkm is offline superhkm  Norway
Parts ordered. Mutilation to come.
Old 9th May 2008, 08:45 PM   #885
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Finally, an affordable CD Transport: the Shigaclone story Send a message via AIM to Peter Daniel
IIRC, the load (lead frame) is 5kg, the spring dia is 1". They are approx. 2" tall , the wire is round and they don't compress more than 0.1" under the load.
To order kits contact me through forum mail.
Old 9th May 2008, 08:46 PM   #886
kevinkr's Avatar
My wife was pretty horrified by the whole mutilation part of it. (Oh, the horror of it.. ) Might best keep loved ones away from the scene of the surgery..
Old 9th May 2008, 09:52 PM   #887
Zigis is offline Zigis  Latvia
Thank you Franz for your kind offer, it is really hard to find DIP package today. I can't send you mail from here, can you mail me to zigisg/at/inbox.lv
Originally posted by Franz Gysi
Finally? Nothing is finally, in my audio setup
Yes, I now this feeling
Peter Daniel, where can I see your DACs ?
Zigis.
Old 9th May 2008, 10:07 PM   #888
JC Fardo is offline JC Fardo  Brazil
JC Fardo's Avatar
Could you please tell us what is the wire diameter. Itīs also a helpful detail, if you donīt mind.
Assuming springs are made of "music" or harmonic wire, we are near to target.
Thanks a lot
JC
Old 9th May 2008, 10:21 PM   #889
Ed LaFontaine is offline Ed LaFontaine  United States
Ed LaFontaine's Avatar
Location: where the Appalachians rise from the Blue Grass
Default Swag
Could you please tell us what is the wire diameter?
Scaling from the photo Peter provided, I'll go out on a limb and guesstimate 0.079", +/- 0.005"
Old 9th May 2008, 10:36 PM   #890
JC Fardo's Avatar
Default Re: Swag
Exactly 2,0mm +/- guestimate margin. Not bad, Ed. Thanks
JC
Finally, an affordable CD Transport: the Shigaclone storyHide this!Advertise here!
