Finally, an affordable CD Transport: the Shigaclone story - Page 789 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 8th June 2014, 08:14 PM   #7881
Erik van Voorst's Avatar
I would say start reading where you left off...gradually you get the whole picture...loads of upgrades...budget is the limit....
To baldly go where no man has gone before................(James Kirk)
Old 9th June 2014, 09:25 AM   #7882
dimkasta's Avatar
Guys have you made any comparisons between 2 and 4 diodes?
I really do not like the idea of wasting half the wave from the transformer...
Tibi how did you choose those Cree diodes for your high grade version? I cannot find them on mouser, but there are other skotcky carbide from Cree available
Second harmonic and wine for everyone...
Old 9th June 2014, 09:42 AM   #7883
tvicol is offline tvicol  Romania
tvicol's Avatar
Send a message via Skype™ to tvicol
With Shiga power supply you get full-wave rectification. You do not waste any wave.
You have a center tap and each wave is rectified by one diode.
You can get CREE diodes from Cree Semiconductor Rectifying Diodes
I use them in all my modifications with excellent results.
Tibi
Vicol Audio
Old 10th June 2014, 12:34 AM   #7884
dimkasta's Avatar
Quick thought.
Anyone tried a single shunt 75R (or 50R as per Jarek's suggestion) resistor at the output, and moving the attenuator to the DAC side of the cable? It should improve SNR at the DAC's input because noise picked up by the cable will be attenuated too, and the higher peak to peak voltage should allow better transfer of high frequency low level harmonics in a lengthy cable.
Old 10th June 2014, 03:40 AM   #7885
tubo is offline tubo  Philippines
hi Dimkasta,
I've not tried this but it seems a good idea. in leu to this, i would like to share to everyone that i have used ldr's on the output. i used 50 ohm to 75ohm pipad as recommended by studiozey. i have compared it to caddock on shunt and shinkoh on series. i must say that the ldr are very natural and very clean. dynamics are to die for. im not going back to passive resistors. the transport i used on this test is the jvc.
i will be comparing the ldr's against vishay on series and caddocks on shunt on the mk2 shiga very soon.
Old 10th June 2014, 06:12 AM   #7886
dimkasta's Avatar
Cool... I still have some from Uriah...
But one more psu sounds a bit off for me...
I ll wait for your results...
Old 29th August 2014, 12:03 PM   #7887
polaron is offline polaron  France
Default No stress!
Originally Posted by tvicol View Post
Few pictures with Shiga prototype chassis.
Tibi
That's funny!
I had a Shigaraki transport in the past, (as well as the Flatfish, but Flatfs muuuuch better!), but the point is that Shigaraki plays considerably well without stress.
I mean for that : having the block chassis not screwed, without suspension.
When I removed the aluminium chassis the sound improved and when I remove the screws, it still improved. Here, no big mass, absortion, just to let the mechanical parts as free as possible.
I'm not an engineer, but I have ears, and these "tweeks" could be heard by everybody when I used to make the demonstration.
Old 29th August 2014, 12:10 PM   #7888
Originally Posted by tubo View Post
hi Dimkasta,
Hi tubo
Please allow me to enter in the conversation just like that.
You're absolutly right!
I also LDR in my gainclone - by the way, Uriah made it for me and it is really good. Now, everytime I have the chance to replace passive resistors by LDRs, I do it. I'm LDRing all over
Old 29th August 2014, 01:00 PM   #7889
Originally Posted by polaron View Post
That's funny!
Note : I am not applying the same to this chassis in the photo. The only reason I'am not buying is that I can't do it in this moment. To many projects. This is a very good one, very simple, very effective and good looking, just the way I like, sincerely. I just wanted to make a point. Shigaraki transport is very nice and good looking, but this one in the photo has not the mistakes done in the original Shigaraki. Sorry Shigaraki, you know that I like you.
Old 2nd October 2014, 03:52 PM   #7890
Salar is offline Salar  Germany
Just a simple question, search did not help:
Does the laser has copper bearings for gliding on the rods? Or is it simply
plastic gliding on the rods?
This thread is 6 years old. Did you experience any problems with longetivity of the transports?
Are all laser transports still running?
All the best,
Salar
Copyright 1999-2017 diyAudio
