Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Finally, an affordable CD Transport: the Shigaclone story
Old 15th August 2013, 12:12 PM   #7351
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Go back one page and look for tivicol (Tibi). He has links at the bottom of his post to his web site, and links to the sign up for the next release.
You could also email or pm him.
Old 19th August 2013, 03:41 PM   #7352
Audiohifi is offline Audiohifi  Singapore
I implemented separate 5V supply using Peter's recommended
regulator.
There is sonic improvememt. But I have a problem. It
takes longer than usual to read TOC, play for a while and skips.
When I reverted back to internal supply, it plays perfectly.
What is causing this problem? Help appreciated.
Goh
Old 20th August 2013, 06:13 AM   #7353
tvicol is offline tvicol  Romania
tvicol's Avatar
Finally, an affordable CD Transport: the Shigaclone story Finally, an affordable CD Transport: the Shigaclone story
regulator.
Goh
You have a grounding issue, or one of your 5V supply is noisy/oscillating.
Take care to keep ground in a star fashion.
Which board do you use - JVC or Shiga ?
Tibi
Vicol Audio
Old 21st August 2013, 12:12 AM   #7354
Tibi
Thank you Tibi. I use JVC boombox board.
I replaced the op amp with lower frequecy one, but still
not reading well.
I will rebuild the regulator and see how it works.
Can Q902 be removed making sure there is 8V supply
to the motor control chip?
BTW is there a provision in you new board for separate 5V
supply and do you have 5V supply board?
regards
Goh
Old 21st August 2013, 09:17 AM   #7355
tvicol's Avatar
Goh,
Check if your regulators are not oscillating with an oscilloscope. Check also if output regulation voltage is in 5V +/-0.25V range.
Q902 can not be removed because IC903 provide system reset as well. If you remove Q902, in order to read TOC, you'll need to power off/on for each CD.
Yes, the Shiga MKII will have separate pcb for several 5V regulators, but in order to keep kit cost low these will not be populated by default. You'll have to buy parts and mount by yourself, or simply use other regulators like tentlabs, jung supergeg, alw etc.
Tibi
Vicol Audio
Old 21st August 2013, 01:36 PM   #7356
dijke308 is offline dijke308  Netherlands
I have some spare JVC RC31 transport for sale and have placed the first one on ebay. Search for Shigaclone cd transport...
Old 23rd August 2013, 03:24 AM   #7357
Goh,
Tibi
Voltages are within range. I will rebuild the regulator using pcb.
Peter Daniel implemented discrete 5V with improvements so I am trying hard.
Thanks Tibi
Goh
Old 27th August 2013, 01:49 PM   #7358
dimkasta is offline dimkasta  Greece
dimkasta's Avatar
I was under the impression that my Salas powering the motors was not very effective with its 500mA. There was no blink on the leds, but the setting was rather marginal. So I boosted it today to give 1A.
There was a distinct increase in performance, but I have to say things are getting ugly in the PSU case... WAY too much heat going on...
I am considering using the 7808 again for that part. I m not really sure it is worth the effort. I will probably keep the extra salas and convert it to 5V in case I decide to separate the clock in the future.
Too many projects... so little time...
Old 16th September 2013, 01:12 PM   #7359
tvicol's Avatar
Prototype Shiga MKII boards are ready. Few more parts to collect and beta testes will have to power up irons and show the skills. :-)
http://www.diyaudio.com/forums/group...ml#post3634129
Tibi
Vicol Audio
Old 17th September 2013, 12:17 PM   #7360
TheGimp's Avatar
Regrettably since I have both of my gen 1 units working, I can't justify the cost of another unit.
Otherwise I'd buy one for comparison.
Finally, an affordable CD Transport: the Shigaclone storyHide this!Advertise here!
