Finally, an affordable CD Transport: the Shigaclone story - Page 712 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 10th April 2013, 09:27 AM   #7111
costa23 is offline costa23  Indonesia
nothing happened . all the button dont worked
Old 10th April 2013, 10:17 AM   #7112
dimkasta's Avatar
does the port switch trigger the TOC reading procedure?
Old 10th April 2013, 10:36 AM   #7113
nbivol is offline nbivol  Turkey
Hello all,
postig some pictures of my Shigaclone with great thanks to all people contributing to this great thread.
Special thanks to Peter who started and developed these simple project into something extraordinary, as all the heroes of this thread which pushed forward the project. During this period I've learned many new things, I personally starting from zero knowledge in electronics with only the desire to build this extraordinary transport.
Thanks all
Built from EZ-31 parts I opted for a separate power supply , twin transformer for 8V and 5V separate lines and Burson regulator for 5v
alluminium enclosure taped with dynamate
mounted on a wooden plate and also side plates of wood
All electronic parts were bought on ebay from different sellers.
Great thanks to all
Old 10th April 2013, 11:35 AM   #7114
nbivol, this looks fantastic! How did you cut the laser slot in the aluminum top? Where did you get the white front plate for the display? Where did you source the box? Can you post a couple more of pics of the innards?
What sort of feet are those on the bottom?
But most of all, how does it sound? :-)
Old 10th April 2013, 12:00 PM   #7115
I have shorted all button and nothing hapenned. Pls help
Old 10th April 2013, 03:33 PM   #7116
tonyptony,thanks for the good words
the case was taken from here Audio Catalog
AL-314B Full Aluminum chassis for Pre-amp or small power amp - Black color version and cutted all opennings with dremel tools ,it cuts alluminium pretty easy ,important thing is to stick the whole box before working with scotch tape to avoid accidental scratches
here you have link for spike-cones
Hi Fi Racks M6 Stainless Steel 15mm Spikes (Set of 4) | eBay
white front plate for the display was taken from original JVS boombox
it sounds really good,very natural,fast and precise,used with TP opus dac.
I did all the mods described by uncle_leon on his site
BG std 1000/25 filtering caps
burson regulator for 5V
C916 BG N 33/16
Output L-pad Shinkoh + CaddockMK132
all the best
Old 11th April 2013, 09:51 AM   #7117
Erik van Voorst's Avatar
Looks great and tidy.
One remark though...I would definitely make a better cable entrance in the alu box to relief the strain on the black/red wire...
To baldly go where no man has gone before................(James Kirk)
Old 11th April 2013, 10:40 AM   #7118
BMW850 is offline BMW850  Netherlands
BMW850's Avatar
Hello nbivol,
Thanks for the great photos.
Great, then we can give each other the hand because I have also no electronic background.
Rudy
Itís not what you know, but who you know ďand where they areĒ
Old 11th April 2013, 10:45 AM   #7119
Erik van Voorst ,thank you very much for your kind words,
considering the great attention that you pay to small details in all your projects you are absolutely right . for the moment I thought to do the sides of the power supply from wooden plates ,just the same as transport unit, and arrived there I will definitely do something better with that cable .
cheers
Old 11th April 2013, 10:57 AM   #7120
Thank you Rudy
Rudy
nbivol
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright ©1999-2016 diyAudio
