Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Finally, an affordable CD Transport: the Shigaclone story
Old 30th March 2013, 11:56 AM   #7061
dimkasta is offline dimkasta  Greece
dimkasta's Avatar
Did some more listening and I think its clearer for me... Paper tape under Tibi's puck is a nonono.
Too many projects... so little time...
Old 30th March 2013, 01:02 PM   #7062
BMW850 is offline BMW850  Netherlands
BMW850's Avatar
Hi Tibi,
I have the CD Puck ordered.
Might be an option, boards of the 5v Salas low voltage shunt regulator because dimkasta have good results with those regs.
Here a picture of Doede his site this is how I mean inclusive the transformer, plug in and play.
These are 5v 1A regs, I think that 80mA will be enough.
Only the 2 motor has more power needed.
Rudy
Itís not what you know, but who you know ďand where they areĒ
Old 30th March 2013, 01:29 PM   #7063
syklab is offline syklab  United States
Originally Posted by BMW850 View Post
No one can help me with this question?
If I connect this +5v wrong I have a problem, I would like to know for sure.
Rudy
The orange wire is the 5V which connects the main pcb and the display pcb.
Old 30th March 2013, 01:45 PM   #7064
BMW850's Avatar
Thanks syklab,
Waiting now for the terminals, when they arrive I go further.
I have no hurry because I can listen every day, to my Shigaclone.
The only goal for me is to make Tibiís Shiga better sounding.
Rudy
Old 30th March 2013, 04:12 PM   #7065
BMW850's Avatar
Hi Skylab,
I look again to your picture and see you use red for GND and purple for +8v
Be aware you make no mistakes with diferent colors.
The other side of the PCB is +8v, on the wrong side the intention was, here the + 8v connection.
Then the error thus made
I have changes the inlet with a fuse
Rudy
Old 30th March 2013, 04:15 PM   #7066
I inserted the cable in the wrong direction, the blue is +8V and reed is ground, I have marked te red cable with a black marker so I won't forget. I will make a correct cable later.
Old 31st March 2013, 06:13 PM   #7067
tonyptony is offline tonyptony  United States
Nothing special to show, except my enclosure (sans top). It is currently drying from its final coat of semi-gloss polyurethane. I decided to stain it Cherry. Looks better in person than in the pic.
You can see that because the cabinet walls are thicker than a standard aluminum enclosure I had to cut a slot for the buttons instead of small holes - the buttons would have never cleared the wall thickness that way. I don't have a router, so I couldn't route out the backside to help.
Considering the last time I did any hobby woodwork was in high school shop class I guess it's not horrible.
Old 31st March 2013, 07:30 PM   #7068
pchw is offline pchw  United States
Hi Syklab,
Did you get the chance to replace the clock with Anton's kit?
I aso have the same kit and eager to hear your impressions.
Thanks!!
- Fred -
Old 31st March 2013, 07:32 PM   #7069
Fred, which kit?
Old 31st March 2013, 07:41 PM   #7070
Hi Tony,
This GB. Contact Anton if you are interested, he may still have the kit or pcb available. Since you are interested in a dedicated PS to the clock, this kit should make it easier. Also, read the last 2 posts for Syklab's question and Anton's answer of how to do the wiring.
- Fred -
Finally, an affordable CD Transport: the Shigaclone storyHide this!Advertise here!
