Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Finally, an affordable CD Transport: the Shigaclone story
Old 28th March 2013, 03:14 PM   #7041
tonyptony is offline tonyptony  United States
Pretty sweet.
Old 28th March 2013, 07:38 PM   #7042
syklab is offline syklab  United States
So frustrated tonight, I bought a new Sanyo laser head so I started out replacing the laser that was playing fine the night before, the new laser can't read any CD at all. I checked the height of the turn atble and measure correct so I start adjusting the vr until it reads the toc but plays with shattered sound only, after spending hours still couldn't get it to play correctly. I put back the original laser but also failed to play, I think I messed up something but couldn't figure out yet, may be the ribbon cable turn bad....I don't know!
Old 28th March 2013, 10:19 PM   #7043
dimkasta is offline dimkasta  Greece
dimkasta's Avatar
Can you check the eye pattern as Tibi described a few posts ago?
Does the sled move freely?
By the way, today the thinness I described yesterday was almost gone. That damn fresh solder...
I later replaced R48 and R49 with Dale CMF55. The initial result was some more clarity and more extension to top and bottom. Especially top. Let s see how this one goes... Tomorrow I ll do some more listening and then try the 100-300-100 pi-pad.
Old 28th March 2013, 10:39 PM   #7044
dimkasta's Avatar
By the way, has anyone tried removing that metal ring on the spindle?
If we do not use a magnetic puck it probably just sits there rattling
Old 29th March 2013, 03:08 PM   #7045
BMW850 is offline BMW850  Netherlands
BMW850's Avatar
Where should I connect this + 5v, connecting to the display bottom.
Connect the + 5v to: 1 2 or 3 to the display?
Rudy
Itís not what you know, but who you know ďand where they areĒ
Old 29th March 2013, 03:36 PM   #7046
I haven't but it seems like if it's removed it might just as easily create a cavity which could lead to vibrational resonances.
Old 29th March 2013, 03:37 PM   #7047
Problem solved, the ribbon cable got bad after a few insertion. Replaced it and things back to normal. Got to get few more for spare, they breeak easy.
Old 29th March 2013, 04:11 PM   #7048
BMW850's Avatar
What is the name of this cable shoe, I have 4 too little.
Myself have 1 broken but I want order 20 pieces spare parts.
No good connection I must this soldering have no special tools for this.
And Yes, this connection breaks so easy
Too bad I had hoped that this cable was already made, plug in and play.
Ready mounted and tested
First, go try this connection then everything directly soldered on the PCB.
Rudy
Old 29th March 2013, 04:55 PM   #7049
Stixx is offline Stixx  Germany
Stixx's Avatar
Those guys seem to be called crimps for pin headers...
I am using pretty much the same ones for another project. pin spacing probably is 2.54mm...
08-50-0114 Molex | Mouser
Old 29th March 2013, 05:19 PM   #7050
BMW850's Avatar
You can find the parts on Tibi's signature the Shigaclone BOM
I have found him:
SPH-002T-P0.5S - JST (JAPAN SOLDERLESS TERMINALS) - CONTACT, 0.05-0.22MM, CUT REEL | Farnell Rom‚nia
Rudy
Finally, an affordable CD Transport: the Shigaclone storyHide this!Advertise here!
