Finally, an affordable CD Transport: the Shigaclone story - Page 687 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 7th March 2013, 12:40 PM   #6861
Originally Posted by tvicol View Post
tonyptony,
Im going to send you parts for one remote and include R52 as well.
Tibi
Thanks Tibi! Hopefully I won't fry that tiny little resistor! I'll have to practice some more on some scrap PCBs I have.
Old 7th March 2013, 07:16 PM   #6862
Is there any advice for how to reliably get those tiny little plug pins on the end of the multiwire cables that go into the inter-board connectors?
Old 7th March 2013, 07:59 PM   #6863
john dozier's Avatar
There is no hope!
Evil looms. Cowboy up. Kill it. Get Paid.
Old 7th March 2013, 11:36 PM   #6864
Hi all.
A replacement for the 78XX and lm317.
the LM2575HVT-adj.
regards
zjaakco
Old 8th March 2013, 01:38 AM   #6865
Here's a picture of the pin connector Tibi supplied with the kit. Is it best to use stranded or solid wire for this? Does the wire get inserted past the large tabs only, or the large tabs and the smaller ones in the middle, before crimping? What's a good tool to use for a reliable crimp? (assume I don't have the actual tool made for this sort of thing - the actual crimp tool costs over 270 Pounds!)
Old 8th March 2013, 05:34 PM   #6866
Default Wiring of 6 pin abd 3 pin cables
When wiring these up, do I keep the connectors in the same orientation when wiring across from the pin of one connector to the other, or is one connector flipped over? I hope I'm being clear. If I expect to run the wires all in parallel from one connector to the other, do I orient the connectors back to back with the same side (of each) facing up, or one of them flipped?
Never mind. I see woodturner_fran answered this a little while ago. The connectors orient back to back with the same side facing up.
Old 8th March 2013, 08:04 PM   #6867
Default No voltages at V1-V4?
Can I check anything on the PCB with just the +8V connector inserted, before I plug in any other cables?
D@mn it! D@mn it! D@amn it! Since I was looking at the upper side of the board I mistook the location of the "+8V" on the PCB as denoting the location of the actual positive side of the voltage rail. I didn't even see the "J6" label on the PCB. I realized that is the alternate method of also identifying Pin 1, but only when it was too late. So for a short time (~10 seconds?) I had the voltage feeding the PCB reversed!
Once I powered down and reversed things the board and display seem to have come on okay. I measure +4.94 VDC at all four testpoints. But I have the bad feeling I probably damaged something. I caught the slightest hint of burning something just before I pulled the power. If anyone can tell me what would happen when this PCB is fed with reversed voltage I'd like to know - but I suspect I won't be happy the hear it.
Old 8th March 2013, 11:40 PM   #6868
Well, I'm not quite sure what to make of this. I finished making all the cables and started checking things one by one after plugging in each cable. The PCB test points seem okay. I powered down and then plugged in the three pin cable for the front panel. The display seems to do what it's supposed to do. Then powered down again and plugged in the 6 pin motor drive cable. As soon as I powered back up the mechanics of the sled started slamming against the stop closest to the hub. I pulled the power immediately.
The sled has had its shorting blob removed and the laser cover is off.
I made that cable by laying out the six wires in parallel, between the connectors which were back to back, both showing their guide bars pointing up.
Old 9th March 2013, 12:47 AM   #6869
I'm attaching a photo of the setup. Right now I have it built on a slab of hardboard so I can get it up and running quickly for testing and evaluation.
If you expand the image to full size you can see that on both ends of the 6 pin cable, at the connectors, I circled the same wire at each end so you can see the orientation. It's a black circle in each case so it may be a little hard to see.
Old 9th March 2013, 12:45 PM   #6870
I tried both of the mechanisms I got from Tibi and they are both slamming at the stops.
Anybody?
Copyright 1999-2017 diyAudio
