Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Finally, an affordable CD Transport: the Shigaclone story
Old 27th February 2013, 08:03 AM   #6801
Erik van Voorst is offline Erik van Voorst  Netherlands
Erik van Voorst's Avatar
Originally Posted by woodturner-fran View Post
You are too kind Erik!!
It is nowhere near as nice a piece of work as the delrin one in your photo above though...
I would like the skills to make that!
Fran
.........but I use yours...
To baldly go where no man has gone before................(James Kirk)
Old 27th February 2013, 12:06 PM   #6802
Today I made the preparations for the three clocks.
I made use of my own Shiga testboard...the Mini PiTbull is too Mini for this
I use miniature plugs so I can switch quite easy....keep you informed...
Old 27th February 2013, 12:10 PM   #6803
Forgot to explain:
The clocks are mounted around the transport with :
On the left: Trichord 4 with their own PSU
On the top: Tent with their own PSU
On the right: Dexa with their own PSU
They all enjoy the same main filtering and Bybees...
Old 27th February 2013, 01:02 PM   #6804
dimkasta is offline dimkasta  Greece
dimkasta's Avatar
Nice rig can t wait to hear your results
Old 27th February 2013, 03:56 PM   #6805
c12mech is offline c12mech  United States
c12mech's Avatar
Looking forward to your observations Erik.
I want to add an AES output to my transport. I have found this drawing for a circuit and would like to know if it will work.
http://vantageaudio.com/photo/spdif.jpg
I also found several drawings with just a transformer between the two but it only seems to work the other way AES-->S/PDIF.
This is more for experimentation than anything else.
Old 27th February 2013, 04:11 PM   #6806
At the last minute a fourth clock will also be tested...
The EZ Ultimate from DIY supply...
http://www.diyhifisupply.com/node/583
I will not test the original resonator or the citizen..I have listened quite a few evenings to both of them......they both sound nice but that is (for me....in my set up....to my ears...blah blah blah) about it.
Old 27th February 2013, 04:19 PM   #6807
Uncle Leon,
I have asked my audiobuddy to give your pi-pad sugestion a try
So he did put an extra 100 ohm (I think he uses Allen Bradleys) as shunt in.
He mailed me enthousiastically his music became "cleaner" more " pin point" and "more resolution" those were his exact words....
Cannot wait to try it out myself now....since I think of him as a very good observer
Old 27th February 2013, 04:31 PM   #6808
dimkasta's Avatar
What suggestion are you talking about? do tell do tell
Old 27th February 2013, 08:40 PM   #6809
uncle_leon is offline uncle_leon  Poland
uncle_leon's Avatar
Originally Posted by Erik van Voorst View Post
I will gladly believe that but I run out of time already....
However if you have them for sale I am your man...
Too bad I hadn't known that you would be interested when I was sending you the stuff for testing. I do have a wood-mod "demo" capacitor pair, i.e. both the same type but one wood-modded and the other one original. I don't really keep any modded caps in stock, I only do the mod on request as it's a lot of work, but I can certainly mod your caps for you if you like.
Uncle Leon,
Usually adding components that are not necessary only makes things worse so I am amazed that my resistor actually improved the sound lol... I am certainly glad to hear he liked it, even in this sub-optimal scenario - but if he thought adding one on top of an Allen-Bradleys was such a noticeable improvement, then he will be positively blown away when both are installed properly
Now, on an unrelated note - I have just done some transformer comparisons. I compared my custom 300VA toroid against a 60VA R-core, and... the R-core was clearly better. The sound was cleaner with improved detail and definition.
As the toroid is a massively over-spec'd 300VA audio grade unit with all the possible bells and whistles, I think it can be safely assumed from this comparison that no toroid can conceivably beat an R-core in a Shigaclone. Of course, this does not mean that R-cores are the best possible choice, as other trafo types (such as the Hammonds recommended by Peter) could turn out to be even better.
Studio Zy - natural, hand-crafted components for hi-end audio.
"Dare to be different, and you may stumble upon something amazing."
Old 27th February 2013, 09:36 PM   #6810
Uncle Leon, I do not know if you got me right the first time but my friend went from an Allen Bradley 300/100 combo to your pi suggestion so only adding another 100 Allen Bradley to the other two Bradleys...
I did not lend "your stuff" to him
Btw received the naked vishays today 100 was okay but a 390 instead of 330 ohm grrrrrrrrr
Finally, an affordable CD Transport: the Shigaclone storyHide this!Advertise here!
