Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Finally, an affordable CD Transport: the Shigaclone story
Old 15th February 2013, 10:42 AM   #6731
uncle_leon is offline uncle_leon  Poland
uncle_leon's Avatar
Originally Posted by alphaigor View Post
If I remember well it was value about 30-50ohm but don't take my word ,start with 10ohm for example and than see what happens.I didn't tried cap.I thought the same about loud but the result was opposite.Maybe the chip did have to do more polarity alternations because the motor reacted slower for chip but enough fast for laser needs,I have no idea.The fact is that the heat sink turned normal when I removed resistor.It is not big problem if you piggyback solder some copper foil on heat sink to increase efficiency.I only know that now when the motor have constant rotation in one direction the chip is nearly cold and not slightly warm like before without the resistor on motor.
I wonder if you could have the best of both worlds by installing some sort of gearbox (slow gear for playback, fast gear for seek). Perhaps a clockmaker would be able to suggest a solution.
Either way, I would also love to see more and better pictures of your rig, and a film would be perfect
@dimkasta - great link, thanks!
Studio Zy - natural, hand-crafted components for hi-end audio.
"Dare to be different, and you may stumble upon something amazing."
Old 15th February 2013, 04:19 PM   #6732
Erik van Voorst is offline Erik van Voorst  Netherlands
Erik van Voorst's Avatar
Today I made a couple of basic modifications to the Mini PiTbull.
First I removed the two smd I slightly bend the heatsink keeping the pressure on the plate not the chip and then cut it away instead of desoldering I find that somehow a better solution.
I installed an E5 using Oscon and made some prep for experimenting with the (in)famous C06.....dropped a wondercap in.....wiring is Mundorf Silver/Gold
First I will ditch the horrible puck and spindle its deviation is exactly in line with what you paid for 5 dollar the laser struggle is sometimes hilarious.
Anyway the contraption is spinning and besides some toc issues okay enough.
To baldly go where no man has gone before................(James Kirk)
Old 15th February 2013, 08:17 PM   #6733
tonyptony is offline tonyptony  United States
Does anyone have a to scale mounting hole template for the turntable? I got some material to begin building my ready-made version and I want to make sure the through holes for my two 1/4"x20 mounting bolts are in the right place.
Old 16th February 2013, 02:18 AM   #6734
alphaigor is offline alphaigor  Croatia
alphaigor's Avatar
Thanks for suggesting the idea.In fact I was thinking about two speed gear but I realized that I don't need remote after 4 mounts of using that version of transport without any more modification.Usually ,during past years I made modifications on daily basis and I was sick of trying to materialize the sound that I imagined.I have destroyed old version and 5 months ago I started new one.It took me over month of thinking and constructing an finally after long years I forget the remote.It is nice feeling.The music is hallucinogen now and that is the point of the story.You fall asleep when starts and wake up when it is finished.If I need certain track during testing I do it manually or press the skipp button while I working on my speaker cable .For a 2m speaker pair cable construction I spend around 130 hours of time so 130 seconds of waiting isn't problem at all.Thanks to this transport I recently constructed new series of signal wires which works exceptional in systems costing from 3000 to 30000eur.The comments of my customers regarding cables are that the timing of the music is fabolous with body and details not covered with mid band presence.That is how I experiencing the sound of the transport and I would hardly developed the cables of such quality if I was using say Ac*****se player costing 150x more which is soulless machine from my point of view and worst of all it have totally wrong timing of the music ,it's boring ,you really fall asleep with it but you don't want to wake up anymore for two reasons ,because sounds bad and because you want to shut yourself after spending 9000eur on useless peace of metal so better fall asleep and forget for awhile.
I must borrow camera from a friend and will try to publish video to show you the machine in action.
Old 16th February 2013, 07:40 AM   #6735
Hi Nemo,
You know I use wire with weight on the gear train.
What would you say would be a "safe" amount of grams (approx) to use...
I have no idea how harmfull it can be to lets say use 10 grams instead of 1 gram.
I really like the one direction motor idea....I never search for tracks unless a friend with cds comes over....
I am putting the caps on the motor soon
The term "soulness" is very well choosen for the other transports once our contraption is in play
Old 16th February 2013, 02:06 PM   #6736
alphaigor's Avatar
Originally Posted by Erik van Voorst View Post
Hi Nemo,
Erik,
I didn't tried more than few grams.I always checked that chip with heat sink and it was OK regarding temperature.I stoped with these few grams because I saw that the gear clearance was lessened to extent to calm much more the confused motor motion.When I applied much more force by hand the skipping occurred so the conclusion was that it is important to find the middle value.I didn't experiment further because after that I passed on air bearing laser guide and the mass loaded thread solution was removed by slight inclination of the air bearing that hold the disc spin motor.I inverted the concept so the gravity regulated with inclination did the thread job.My conclusion was that is more important finding golden ratio of applied gravity rather than insist on maximal because sound developed was too heavy ,it was correct but too heavy to full enjoy it ,at least for me.That would be maybe topic about tastes but since we are DIY-ers the end result depend only to our own hearing needs what is great.If audio would be only objective that would be tough task for my ears ,I wouldn't listen to the music except live events if i could not personalize the sound system.I went with mass of 30 gram applied on air bearing and have found out that the slight inclination is sounding better.The resulting balance of overall sound was correct.The lesson for me is that that CD game is adjustement of different resonances in the cd system ,all together ,rather than obligatory kill some of them immediately ,it is energy flow that together give certain result ,as in every other component in the system ,like TT device for example or human interaction synergy after all and there is no ready recipe how to make it since result is mostly ear visible ;at first 7g and 3g seems pretty the same but the consequences may be very different. Sorry ,but I moved to fast with that project so I can't give you any certain answer regarding original mechanism and I have bad habit not to document my findings but on the other side this is good because person don't imprison himself by some drawings and data.Experiment can only tell you.I only know that the laser sled friction is the significant enemy of the cd sound so I went to frictionless air bearing.The sound of cd is very obvious to mechanical feel of various components involved in this job.If movement is smooth the sound is alike.If movement is stressed by friction the listening is more stressful too.This can be heard on laser noise ,the less you hear from it the better it is in my experience. That's the proof that laser behave more like walk in the park instead of running like hunting dog in the woods.Cd design seems easy ,like many people believe about 1/0 unimportance and think that is only needed any 75ohm cable to do the job.They don't realize that the voltage is carrying the 1/0 information which is lately decoded in other place and the cable must be as good as possible like every other signal cable in the audio chain.It carries many mHz over it attached to voltage so resonance control must be applied there too.This is the only one of many variables in the cd guess chain.
Yes the skip function is useful for evaluation and otherwise not desired very much if you chose right material.
Let us informed on capacitor mod results ,I am curious.
Beside soulless I would add term boneless too as many other more and unless we didn't discovered this beauty thanks to Peter generous share I never needed to find these words since all players sounded more or less the same .We don't develop only the music perception but our vocabulary too ,we are blessed persons in many ways.
Old 16th February 2013, 09:29 PM   #6737
dimkasta is offline dimkasta  Greece
dimkasta's Avatar
I m really curious about the motor cap too...
I ve been seeing them in all motors everywhere... from small RC cars to whatever I could think of. Not seeing one here was really weird.
The nice thing is that the motor PCB makes it really easy to mount a ceramic bead right on the motor terminals
Old 16th February 2013, 09:44 PM   #6738
woodturner-fran is offline woodturner-fran  Ireland
Please do give us the skinny on the motor caps - sizes, types, values etc!!
Old 16th February 2013, 09:45 PM   #6739
dimkasta's Avatar
Typically you will want to use anywhere from one to three 0.1 F ceramic capacitors soldered as close to the motor casing as possible.
For greater noise suppression, you can solder two capacitors to your motor, one from each motor terminal to the motor case as shown in the picture to the right.
For the greatest noise suppression, you can solder in all three capacitors: one across the terminals and one from each terminal to the motor case.
Old 16th February 2013, 09:46 PM   #6740
And, are these on the motor terminals?
Finally, an affordable CD Transport: the Shigaclone storyHide this!Advertise here!
