| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#6671 |
Please also note that LCD backlight have a top protection foil. This was not removed.
Also, glass LCD have a top and bottom protection foil. These have not been removed either. All these protection foils can be removed very easy with free hand or with a small tweezers. Regards, Tibi Last edited by tvicol; 6th February 2013 at 08:26 AM. |
#6672 | ||
![]() Quote:
Studio Zèy - natural, hand-crafted components for hi-end audio. "Dare to be different, and you may stumble upon something amazing." |
#6673 | |
Of course, I should have thought of that myself before writing! Sorry about that. As I recall (since once again I can't get to some sites from work), you have two varieties of resistors that could work in this application. Could you characterize the differences between how the two solutions sound in this position? (I guess I could wait until I get home to check your site... )
#6674 |
![]() Today I ordered a Teddy Super Regulator for the 8 volt line for the Mini PiTbull Mark II.....just to experiment. I expect it to sound better than my ALWSR Super Regulator since this one makes use of a gyrator...maybe..... I will compare in due time with ears only ![]() BTW I do not know if anyone bought an ALWSR lately but it seems rather difficult/impossible to order
To baldly go where no man has gone before................(James Kirk) Last edited by Erik van Voorst; 6th February 2013 at 06:50 PM. |
#6675 | |
I found the TI document. It is worth reading. http://www.ti.com/lit/an/sloa069/sloa069.pdf Regards, Tibi |
#6676 | |
#6677 | |
i tried both methods but problem is continuing.. after applying some super glue, i realized that shaft movement is coming from motor.. i do not have a digital caliper to measure exactly but its about 0.5 milimeter.. Tibi, do i need a new transport or is it possible to fix it with just a motor replacement? thanks.. |
#6678 |
endia,
There is some movement of the motor shaft in the vertical relative to the motor resting against the trust plate and picking the shaft up a far as it will go in the vertical, which is about .24 mm, or .009" in my sample, which is not much...and even .5 mm your measured is .018", which is not much travel. With a CD on the CD Turntable and/or a Clamp, well, in operation it should be the same or less...and the laser servos can compensate for that. Your note does not specific what the problem is at this point. You indicated the original issue was resolved, which was the motor not "seeing" the limit switch, which you traced to the cable and corrected. Describe exactly what is happening now.
Sean Henderson |
#6679 |
Sean, sorry for the unclear post, i didn't know that movement is normal..
so my problem is; when i put a cd, laser head continuously trying to read and fighting against cd and doesn't read any of i tried about ten of them which some are original.. i'm not trying much of cd to prevent laser head to get damaged if it does.. this is what it does when powered on: 2013 02 07 20 35 50 - YouTube thanks a lot.. |
#6680 |
endia,
I don´t see any laser light. This should be seen as a white light trough the camera. Have you removed CD laser diode static protection ? Regards, Tibi |
