| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#6651 | |
Keep 16 flat cable free of any tension. This may lead to errors in operation. Regards, Tibi |
#6652 | |
For your Compiled Shigaclone Guide, attached is the datasheet of CSC1469XH. Regards, Tibi |
#6653 |
I am in the process of building a third player.
This one will be called Mini PiTbull Mark II Obviuosly I will try to upgrade there where possible starting with the SPDIF and the C906. I will try to put it in a post....uncle Leon will provide me with " his stuff" and I will challenge a few resistor and caps in the process.
To baldly go where no man has gone before................(James Kirk) |
#6654 |
It will be a playerboard and a seperate psu this time.
Mechanically I took a slab 12 mm copper and a massive woodenboard with a marble plate glued underneath....so very inert. ![]() It is called Mini but the sound/music I am after will be great.... ![]()
#6655 |
Good luck Erik. You have certainly covered a lot of ground so far, which has been of benefit to all of us.
Are you planning on using Tibi's PS PCB with upgraded components or building your own PS from scratch? I've been thinking that the PS and display each should probably be shielded to keep any stray emissions from getting near the player. Of course with the PS in a separate box that may not be needed, but I know some supplies work better with very short leads to the load while others are okay with longer leads. I've been wondering about the PS based on Tibi's PCB and whether it would be better positioned in a separate box, or if it is best placed close to the load. |
#6656 |
It is always a " no free lunch situation" .
The idea is psu with transformer(s) rectification, line filter in the box....and regulators, clock and (swich on/off) display on the board.... I will be using the boomboxboard.....but that is mainly because I have a lot of them and I want to mutulate them ![]() BTW I am building this for my (best) friend so he has some saying in the matter (at least I will make him think that ![]() ) and he wants a small player in sight and the PSU tucked away.
To baldly go where no man has gone before................(James Kirk) Last edited by Erik van Voorst; 4th February 2013 at 12:51 PM. |
#6657 |
Hi Erik,
Great to see you building one of these!!! I await with bated breath your blow by blow accounts!!! I have also received 2 from tibi but have yet to make a chassis. It will be over the next month or so before I get to it I think. Fran |
#6658 | |||
Studio Zèy - natural, hand-crafted components for hi-end audio. "Dare to be different, and you may stumble upon something amazing." Last edited by uncle_leon; 4th February 2013 at 02:05 PM. |
#6659 | |
#6660 |
Ok, here it comes again!
Best sound I've had after a lot of experimenting with the output resistors are: Handmade from uncle leon Rf attenuators from mini circuits. Fran |
