Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Finally, an affordable CD Transport: the Shigaclone story
Old 28th January 2013, 08:24 AM   #6611
syklab is offline syklab  United States
Hi Tibi,
Very good eye you have, I taped a thin piece of cloth under the puck to see if it can damp out some of the vibration from disk wobbling but not much of improvement.
Old 28th January 2013, 08:35 AM   #6612
dimkasta is offline dimkasta  Greece
dimkasta's Avatar
Thanks a lot Tibi. I hope to get the new puck soon.
Measuring the disc distance as per Sean's instructions, it seems to be only slightly off (about 0,1mm).
I ll try to raise it slightly and see if this fixes the clicking/bumping thing.
Old 28th January 2013, 08:43 AM   #6613
tvicol is offline tvicol  Romania
tvicol's Avatar
Finally, an affordable CD Transport: the Shigaclone story Finally, an affordable CD Transport: the Shigaclone story
Shiga case project and CD puck dimensions are available in PNG and CDR - Corel Draw format.
You can download them from vicol audio : shiga CD transport
With these files you can build your own CD puck and Shiga case.
Please note, some files have big resolution and may overload your PC.
Be patient till files are opened.
Tibi
Vicol Audio
Old 28th January 2013, 08:53 AM   #6614
tvicol's Avatar
Originally Posted by syklab View Post
Hi Tibi,
Well this will make things even worse.
Seems like I need to send to you another CD puck as well.
Tibi
Vicol Audio
Old 28th January 2013, 01:06 PM   #6615
Sean Henderson is offline Sean Henderson  United States
syklab,
The 19.58 mm was measured from the TOP of the CD Turntable, point A, without a CD or the Clamp resting on it...to the top of the chassis, or point B in your photo.
If it is easier to measure this way...from the Bottom of the CD Turntable to the top of the chassis, or point B in your photo, the measurement is 17.34 mm. For reference, the thickness of my CD Turntable samples is 2.24 mm.
Is the 19.58mm measured between point A and B of the picture below?
Sean Henderson
Old 28th January 2013, 04:42 PM   #6616
Hi Tibi,
Seems to have problem trying to download the full image on the SHIGA case drawing and Corel Draw file, I am using IE8 and the screen just go blank. Can you provide a zip version?
Old 28th January 2013, 05:35 PM   #6617
tvicol's Avatar
Hi Tibi,
Right click and save as. PNG file is not big but have very high resolution.
Anyhow, corel draw is what you need.
Tibi
Vicol Audio
Old 28th January 2013, 05:39 PM   #6618
dimkasta's Avatar
I tried today with a self-made puck made out of 4 CDs glued on top of each other. The wobling was reduced significantly (some remained probably because I glued the CDs in a harry and they are not identical), although the motor was obviously coping to move the weight. I tried with 3 and it seems to behave nicely. Now I am looking for a way to keep them centered. I m thinking of some plastic pieces glued to their edge.
With this change it managed to read some more CDs. However it still refuses to read the Metallica - Metallica CD. It simply quits after a second or two and the CD keeps spinning with inertia until it halts after slowing down but by bit by friction.
I tried to move the plastic head a bit further from the metal plate to match the measurements given above (needs less than half a mm), but it just won t move. I have applied some significant force to it including some self-devised levers to try to move it from its inner plastic and not stress the disc base, but it just won t move... I m scared I might break it if I try any harder.
Old 28th January 2013, 06:16 PM   #6619
dimkasta's Avatar
And now I have bent the shaft....
Tibi are there any spares left?
Old 28th January 2013, 06:41 PM   #6620
tvicol's Avatar
Yes, I'll send one with new CD puck.
Tibi
Vicol Audio
Finally, an affordable CD Transport: the Shigaclone storyHide this!Advertise here!
