Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Finally, an affordable CD Transport: the Shigaclone story
Old 24th January 2013, 06:25 AM   #6581
syklab is offline syklab  United States
Hi Tibi,
I will try to use my soldering iron for reheating those pins. Will get back later.
Old 24th January 2013, 03:52 PM   #6582
Hi Tibi,
Finally found the problem and fixed it. The CD platter was loosen a bit and it was pushed in by a small amount which causes probelm in focusing correctly. I pull the platter slightly upward, tested with cdrom, SACD and those weren't able to read before, all can be read without probelm. Laser is not hitting the CD neither. Tomorrow I will put a drop of glue in the center of the platter to fix the position. It is playing nice music now. Thanks.
Like your case design, any price indication ?
Old 24th January 2013, 05:17 PM   #6583
gueri is offline gueri
Yes. I'm waiting to be able to buy it on the vicol-audio web!
I need a case for my shiga
Old 25th January 2013, 06:14 AM   #6584
tvicol is offline tvicol  Romania
tvicol's Avatar
Finally, an affordable CD Transport: the Shigaclone story Finally, an affordable CD Transport: the Shigaclone story
Hi Tibi,
Many thanks for your diagnostic, Syklab.
The case presented here is only a prototype. In order to make a product I need to get a source for all case parts. This is the hard part. Afther that I can calculate final price and make the product available in webshop.
There will be at least two versions and two price ranges based on different materials. One cheap and one expensive.
Tibi
Vicol Audio
Old 25th January 2013, 06:19 AM   #6585
tvicol's Avatar
There are few orders who need to be shipped in order to close this GB. Good news, I just received last missing components and all orders will be shipped by the end of next week.
Sourcing the parts is a very hard job !!!
Appreciate very much your patience and understanding.
Tibi
Vicol Audio
Old 25th January 2013, 07:44 AM   #6586
APK is offline APK  United Kingdom
Hi Tibi
Many thanks,waiting with anticipation.
Tony
Old 26th January 2013, 05:00 PM   #6587
brgds is offline brgds  Poland
Hi Tibi,
my colleagues at audiostereo.pl have found a discrepancy between the original and the new clone both in schematics and PCB: R36 that is connected to pin 42 (-RFS) on the second end should be connected to V1/VCC1 (analog) not to V2/VCC2 (digital), right?
Andy
Andy
Old 26th January 2013, 05:27 PM   #6588
tvicol's Avatar
Originally Posted by brgds View Post
Hi Tibi,
Andy
Hi Andy,
Many thanks for this very good observation. In case you are using separate power supply on ASP, it make sense to connect R36 to analog power section. Please also note that datasheet clearly specify that Vcc1 and Vcc2 should have same potential otherwise the chip will not work. With this in mind will be more indicated to provide a very clean power supply to pin diodes instead splitting the power for ASP.
IŽll come with more modifications when I finish with shippings.
Tibi
Vicol Audio
Old 26th January 2013, 06:59 PM   #6589
j baldam is offline j baldam  United Kingdom
after giving up on my clone I have bought a Rega apollo player.
To my surprise it has the same transport as the clone and for this model they have given up on the puck and have used the 3 ball bearing type.
http://i1095.photobucket.com/albums/...pg_310x310.jpg
Old 26th January 2013, 07:45 PM   #6590
dimkasta is offline dimkasta  Greece
dimkasta's Avatar
Tibi I have just hooked up my kit and it seems to act strangely.
When I power it up, the motor that returns the eye to the center seems to work continuously making the plastic suspension thingy go ticktcitckitck and nothing more happens. LCD shows only the dashes flash.
Have I connected something wrong?
thanks again for a wonderful kit
Dim
Finally, an affordable CD Transport: the Shigaclone storyHide this!Advertise here!
