Finally, an affordable CD Transport: the Shigaclone story - Page 646 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 12th November 2012, 08:18 AM   #6451
dimkasta's Avatar
Tibi the link points to an empty document
Old 12th November 2012, 08:25 AM   #6452
tvicol is offline tvicol  Romania
tvicol's Avatar
Send a message via Skype™ to tvicol
Thanks for observation.
Have corrected, please confirm if its OK.
Thanks & Regards,
Tibi
Vicol Audio
Old 12th November 2012, 08:49 AM   #6453
dimkasta's Avatar
Seems ok now
Old 12th November 2012, 09:46 PM   #6454
The connectors that came with the kit are small - and these awkward thums don't make it any easier!! I found this little video on youtube and it makes the process of soldering them much easier (I'm guessing most here won't have the proper crimping tool). I went and soldered up the second set tonight in 1/4 the time with perfect success. I think the key is that you only strip a tiny amount (2mm) of the end of the wire.
https://www.youtube.com/watch?v=gjmVMsEuxbo
(the guy is making up an adaptor cable)
Fran
Old 13th November 2012, 07:39 AM   #6455
Tibi - a quick question regarding the contrast modification: There is no pot installed at P1. Do I need to install a pot at this location in addition to removing L7 etc? If I do need a pot what value (2k?)
Cheers
Fran
Old 13th November 2012, 07:51 AM   #6456
tvicol's Avatar
Cheers
Fran
The 2K pot will only change backlight intensity.
For contrast you need to follow modifications posted on
and
or look in documentation https://docs.google.com/document/d/1...-j9X4b7Q0/edit
page 9.
Tibi
Vicol Audio
Old 14th November 2012, 11:02 AM   #6457
mekr is offline mekr  India
i am looking to buy a Shigaclone transport,preferably fully assembled or in kit form with outer box casing also,can the readers recommend fromwhere shigaclone is possible to source,though Vicol is selling this kit,but i will need to source outer casing from other supplier.
Old 14th November 2012, 09:48 PM   #6458
Tibi: sorry, another question! The contrast mod calls for a 1.2k resistor. Would a 1k do instead? The reason I ask is that 1k smd are easy enough to find and pull from scavenged pcbs, but 1.2k would be a mouser order....
Fran
Old 15th November 2012, 05:10 AM   #6459
tvicol's Avatar
Hi Fran,
Any resistor between 1K and 1K8 will do a good job.
Tibi
Vicol Audio
Old 15th November 2012, 07:16 PM   #6460
So I went to do this mod this evening. Big fingers do not help!
Anyway, I cut the 2 traces OK and used 2 soldering irons to remove L7, fitted the link between the 2 capacitors. I fitted a 1.5k resistor in place of L7, but unfortunately I broke L7 when positioning it on the new pads. I simply bridged the 2 pads - I hope this is Ok - it seems to be.
I got a little improvement in contrast, and I fitted a pot for P1. Using the 2 together the situation is better. Its not as good as the original shiga, but good nonetheless.
Thanks again Tibi. Is the value of L7 critical?
Fran
Copyright 1999-2017 diyAudio
