Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Finally, an affordable CD Transport: the Shigaclone story
Old 2nd November 2012, 10:30 AM   #6421
tvicol is offline tvicol  Romania
tvicol's Avatar
Finally, an affordable CD Transport: the Shigaclone story Finally, an affordable CD Transport: the Shigaclone story
Many thanks as well !
Tibi
Vicol Audio
Old 4th November 2012, 03:03 PM   #6422
lucylu is offline lucylu  England
The leads that came with my shiggy think they are jst-xh i am finding it very hard to make up, my big fingers ,.Does anybody know where i can purchase these ready made ? i have had a quick look around but no luck cheers john
Old 5th November 2012, 05:17 AM   #6423
dmy is offline dmy  United States
I've been following on this great transport thread for awhile and finally finished my unit. Out of the box it sounded quite nice. Thanks for such a great project.
Please allow me to ask a few questions.
How important is the 300 ohms and 100 ohms resister at the digital out ? I notice some use caddock, does resistor quality impact the sonic?
Is the following SanYo laser pickup on Ebay a replacement for the EZ-31?
SF-P101N 16 PIN SANYO LASEREINHEIT mit Mechanismus
Many thanks for your comments
Old 5th November 2012, 08:23 AM   #6424
tvicol's Avatar
Any component have his own sonic signature and therefore will have a sonic impact. Some components add more signature than others.
Now the question is: Is your system capable to make such difference ?.
There is no e-bay link in your message.
For your reference CD mechanics datasheet is on http://vicol-audio.ro/docs/DA11VZ.pdf
Tibi
Vicol Audio
Old 5th November 2012, 01:58 PM   #6425
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Originally Posted by tvicol View Post
Placing the resistor in that place is not the best option because LC78601 pin 22 will be affected as well and this may degrade DSP performance.
The mod can not be performed if LC78601 was soldered.
You need to perform the mod before soldering this chip.
First you need to cut the trace between pin 40 and pin 22 as per top_modification.jpg - left picture.
Than, turn the board on bottom and perform the modification as per bottom_modification - right picture. Instead L7 put a 1K2 resistor or a 2K potentiometer to get your preferred contrast and make a strap between two pads. The strap will bring back Vcc to pin 22.
Thats all.
Tibi
Thanks Tibi.
As an additional change, make the cut shown in yellow, scrape the solder mask from two places on each side of the cut, and place the inductor removed in Tibi's instructions (L7) at this location. Now the filtering effect of the inductor and caps is still present.
Steven
Old 5th November 2012, 02:29 PM   #6426
tvicol's Avatar
Originally Posted by TheGimp View Post
Thanks Tibi.
Steven
Excellent observation !
Thank you Steven !
Tibi
Vicol Audio
Old 6th November 2012, 12:13 AM   #6427
tonyptony is offline tonyptony  United States
Tibi, I've been sort of following what you and Steven have been doing here, but I must have missed something. It's not quite clear to me what this is supposed to do, or why it may be necessary.
BTW, my stuff is still colored Orange/Brown. What does that mean?
Old 6th November 2012, 01:28 AM   #6428
skippyboy is offline skippyboy  Australia
skippyboy's Avatar
Hi Tibi,
Received package today. All is well and i like the "pink" barby doll wrapping paper.
Thank you for a great job.
Rob
Old 6th November 2012, 01:42 AM   #6429
uncle_leon is offline uncle_leon  Poland
uncle_leon's Avatar
Hi Dmy, allow me to share my humble opinion on the subject. I did a test similar to my "Big capacitor test", where I compared virtually every audio-grade resistor on the market at the Shiga output. I followed my usual methodology for such tests.
I would say the difference between an average resistor and another average resistor is typically small and requires considerable focus to pick up. However, the difference between an average resistor pair, and the best resistor pair (Vishay/Caddock in this case) is quite significant and easily discernible.
Likewise, the difference between the best resistor pair and the attenuator mentioned by Fran (woodturneer-fran) is quite obvious.
My feeling is, output resistors are less important than the critical caps (i.e. filter caps, C916/C43, C8/906); they are more or less on par with the less important caps, and somewhat more important than digital cable, diodes, transformer or puck.
Please have a look at my "Compiled Shigaclone guide" for more detailed descriptions. The guide is not really finished yet, as I did not have as much free time as I had hoped - but perhaps it will be of some use even in its present form.
Studio Zy - natural, hand-crafted components for hi-end audio.
"Dare to be different, and you may stumble upon something amazing."
Old 6th November 2012, 02:29 AM   #6430
Tibi
Here is the link. Thanks
SF P101N 16 Pin Sanyo LASEREINHEIT Mit Mechanismus | eBay
Finally, an affordable CD Transport: the Shigaclone storyHide this!Advertise here!
